302 Engine Problems
Old Mar 3, 2011 | 10:38 AM
Huge Salad Fork's Avatar
Huge Salad Fork
On both gaskets, the top four coolant channel holes all have small steam holes. For the front two, the upper one is blocked and the lower of the two has a small steam hole. Everything else is open.
Reading what you wrote this sounds normal. I also found out that the blocked coolant drain was actually a bolt hole that looks exactly like the coolant drain on the other side. My drains are fine. This all means to me that something else caused my problems. Could it be just all that gunk in there? Could that cause main bearings to start going and a bent pushrod? This motor has under 100k miles on it.
Dannym
21
Apr 13, 2026 08:54 AM
-Jim G
18
Jun 23, 2022 12:24 PM
F1Hunter
Mar 13, 2017 03:58 AM
destroy
Mar 6, 2017 09:28 PM
BigF350
Mar 17, 2010 10:52 AM
