Need everyones advice
Old Oct 31, 2010 | 08:03 PM
TheDocta's Avatar
TheDocta
I currently have a 1988 7.3 idi with a banks sidewinder turbo kit on it. I buying a 1993 and 1/2 7.3 idi with a factory turbo because my current motors reading a little bit low on compression and i can get the new motor for less then the cost of a rebuild kit+machine shop. I wana rebuild it to be stronger.
What turbo setup would be better to use?
Im gonna upgrade injectors while im doing it, what else can I do to make a little bit more power?
Thank you!
Old Oct 31, 2010 | 09:20 PM
94 smokin stroker's Avatar
94 smokin stroker
No question use the banks system sell the stock system to get injectors (: As far as performance u can get a moose ip and injectors and the cam grind from typ4 thats about it other than lower compresion for more boost.
Old Oct 31, 2010 | 10:50 PM
mabc926's Avatar
mabc926
Keep the factory turbo, even though it says Ford it's an ATS turbo, and it would be easier to get parts for.
As for the Banks I've heard getting parts for them is getting tricky.
Old Nov 1, 2010 | 08:47 AM
NorthernDiesel's Avatar
NorthernDiesel
Agreed. but disagreed!
Harder to get parts, but the Banks system hands the factory turbo's a** on a plate! I upgraded factory to Banks, its not even comparable!
Old Nov 1, 2010 | 02:08 PM
TheDocta's Avatar
TheDocta
how much is a moose ip
where can i find info on the cam?
and as far as injectors i have been told to go with some delphi injectors
everyone think thats the correct route to go?
Old Nov 1, 2010 | 02:21 PM
swooshcmk's Avatar
swooshcmk
I haven't driven a banks one, but I've got a factory with the 3" down pipe and it's plenty of turbo. No problem pushing 13-14psi boost when I've got a load on it, I'll see about 10-12psi if I really put my foot into it empty. Lots of people complain about working on the trucks with turbos, but I just did injectors and injection pump last night and it was a piece of cake - didn't have to touch a thing on the turbo. Maybe everyone that complains that a turbo makes it so much more difficult to work on has a Banks
Old Nov 1, 2010 | 03:16 PM
TheDocta's Avatar
TheDocta
did you make or buy your down pipe?
i have minimal exhaust ie just a 3" to a 4" single stack so either way i think i should be good, i may look at upgrading the dp depending on what i find, to be honest i have never really looked at mine before
Old Nov 1, 2010 | 03:34 PM
swooshcmk's Avatar
swooshcmk
I got my turbo from a junkyard. The previous owner of the truck had done the ATS 3" upgrade for the downpipe, however the junkyard sliced the down pipe in 1/4th with a torch so All I had was the first few inches out of the elbow. I calculated what I'd need for bends and made a trip to the local exhaust shop and 20 bucks later I had a new downpipe. I just welded it onto stub of a down pipe I had left, slid it in place and worked great.
Old Nov 1, 2010 | 05:38 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
a moose ip is having yours rebuilt with some secrete tricks and meticulously inspected with specs set properly.
if your asking about price,you likely don't want one.
(think pricing of what used turbo's go for,for a ballpark figure.)
cam info can be found here:
https://www.ford-trucks.com/forums/9...-cam-typ4.html
those are good injectors.
Old Nov 1, 2010 | 05:41 PM
FORDF250HDXLT
was your factory worn out and with the stock crushed down pipe though?
people seem to be having trouble getting the larger ATS down pipe outlets iv been noticing.
TheDocta,
hit me up with a pm once you decide which turbo you'll be selling.
as long as she has a waste gate,i don't care who makes it.
unless you have plans for it already.if not id like to get first offer.
Old Nov 1, 2010 | 06:00 PM
TheDocta's Avatar
TheDocta
well i have 3 injection pumps at the moment to choose from
i have 2 stock, one needs a rebuild one works fine and i have a brand new one from napa auto parts
either way my friend whos a diesel mechanic will want to turn it up a small bit im sure
Old Nov 1, 2010 | 06:04 PM
mabc926's Avatar
mabc926
Put on the one that's fine, have the bad one rebuilt into a moose pump, then put that one on your truck and save the other one, and then sell the napa one.
Old Nov 1, 2010 | 07:30 PM
TheDocta's Avatar
TheDocta
is the moose pump just specifications that you adjust your pump to or do you send it somewhere to be re manufactured?
Old Nov 1, 2010 | 07:37 PM
mabc926's Avatar
mabc926
You send your pump out and have it rebuilt, that's why it's a good idea to have an extra pump to send so your truck isn't sitting the whole time.
Here's a thread on the moose pumps:
https://www.ford-trucks.com/forums/9...-typefour.html
Fordboy350
Dec 26, 2012 02:32 PM
pre-stroketurbo
Feb 22, 2012 11:37 AM
RangerHaywood
33
Apr 6, 2011 09:38 PM
93idi7.3
Mar 16, 2011 09:44 PM
