Rear Leaf Spring Hangers
Old Oct 31, 2010 | 07:47 PM
aj197816134's Avatar
aj197816134
Recently I have noticed my sources offering aftermarket rear hangers and shackles. I currently have to replace the rear hangers on a 95 F 150 What my question is? What is the quality difference between the aftermarket and the OEM has anyone had them side by side? I was told by someone they might be just reboxed OEM. Anyone with any insights?
Old Oct 31, 2010 | 10:22 PM
GLR's Avatar
GLR
When I did the rear frame brackets on my 86 I bought them from a Ford dealer for about $35. I think aftermarket ones are about the same price. Rock Auto, one of out sponsors has the frame mount (Dorman) for around $20. RockAuto Auto Parts
Old Oct 31, 2010 | 10:42 PM
boots6868's Avatar
boots6868
I used the Dormans from Ebay on my 88 f-250 and i have a utility box on the back my truck weighs 8200 empty! no problems and ive hauled a cube of cinder block and the sand and the mortar at the same time. pretty happy with the dormans.
Old Oct 31, 2010 | 10:52 PM
aj197816134
I was going for the DORMAN'S. I seen some other version, but havent had them all to compare. FORD raised their prices, I buy from same dealer all the time for work, and for some reason for decided to go and raise prices.
Old Oct 31, 2010 | 11:01 PM
biscwgn's Avatar
biscwgn
Leaf Springs and Suspension Parts by Auto and Truck Springs Ask for Bob just did a complete front and rear suspension on my 96 F250 his spring hangars and hardware are the nicest i've seen and are the cheapest price also.
Old Nov 1, 2010 | 01:10 AM
cj06's Avatar
cj06
have you thought of flipping your shackles over ?
Sky's Off-road Design - Home
Old Nov 1, 2010 | 01:30 AM
aj197816134
Not Familiar with this? Explain why? and the benefits?
Old Nov 1, 2010 | 02:03 AM
cj06's Avatar
cj06
all depends what you want to do with your truck . if you are looking to lift it the shackle flip will add 4-5 inches of lift , if you have blocks on the back then you can do away with them and sit about the same or 2 inches higher than stock ( thats with 2 inch blocks )
the truck should ride a little better but a lot depends on your springs
Old Nov 1, 2010 | 09:03 AM
IrishChef's Avatar
IrishChef
Stengle Brothers....about $25 each.
Old Nov 29, 2010 | 05:29 PM
TNT1968's Avatar
TNT1968
Ford F SERIES Rear Leaf Spring Hanger/Shackle Assembly Kit, Complete, fits 3" Wide Leaf Spring **FREE SHIPPING**
339-295
Does the Stengel Bros unit also use grade 8 bolts? If so, that's what I'm gettin'.
Old Nov 29, 2010 | 05:56 PM
buck_'s Avatar
buck_
I just replaced all four of mine plus the shackles and the bushings. I went back to Ford.
I will not use "made in China" parts! Junk, as far as I am concerned.
Old Nov 29, 2010 | 06:13 PM
TNT1968's Avatar
TNT1968
Do you know how much Ford charged you for a RR spring hanger,Hanger mounting hardware, a shackle, two spring eye bolts/nuts, & bushings?
Old Nov 29, 2010 | 06:25 PM
buck_'s Avatar
buck_
Are you really asking a question or being a smart butt???
If serious I'll have to dig up receipts for the parts.
Old Nov 29, 2010 | 06:32 PM
TNT1968's Avatar
TNT1968
I'm asking. I could see how I worded the question it could be read a couple of different ways. I should have asked "Do you remember...".
Old Nov 29, 2010 | 06:36 PM
danr1's Avatar
danr1
If a truck rusted out to the point it requires those parts replaced, realistically what are the odds it will outlive yet another set of hangers/shackles, even if what is used is the cheaper "made in China" type replacement parts?
