6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Water separator ??
Old Oct 31, 2010 | 02:00 PM
CLBF250's Avatar
CLBF250
Water separator ??
I tried to move the lever to open my water separator and can not get it to move. When I do get it free is there anything I can do to keep this from happening again, I do live in the salty road north! 08 ps cc 250
Old Oct 31, 2010 | 02:21 PM
CLBF250's Avatar
CLBF250
ok, got open and gettin a slow drip, havent looked in container yet. i will let in drain for a bit more.
Old Oct 31, 2010 | 03:17 PM
senix's Avatar
senix
probably need to remove the fuel filter and shine a light in there and make sure all is clean. Seems to be lot of this lately.
Old Oct 31, 2010 | 04:30 PM
longview1's Avatar
longview1
Banned
Quick question, I just checked mine last night and had a continuous drip for a min or so then I closed it. It smelled like diesel and not water. Will it drip fuel too or just water??
Old Oct 31, 2010 | 04:57 PM
senix's Avatar
senix
it should drip both, water or maybe just fuel or a mixture. Catch it in a container and then let it sit and then it will separate if you cannot tell the difference.
Old Oct 31, 2010 | 07:00 PM
longview1's Avatar
longview1
Banned
Ok, So let it drain to nothing comes out then? Ive done a couple on dodges and a few drips came out and that was it.
Old Oct 31, 2010 | 07:06 PM
senix's Avatar
senix
let it run till it is a steady stream, no breaks in the stream as it flows, look at it and if it looks good as it goes in the container then you should be fine. 30 second-1 minute at most and all should be out.
Old Oct 31, 2010 | 08:08 PM
StanleyZ's Avatar
StanleyZ
I'm told they will drain more robustly if you open the fuel cap. I've never had that problem. In fact mine wouldn't stop running and I had to have it replaced.
Old Nov 2, 2010 | 11:00 AM
seanjackmc's Avatar
seanjackmc
So after reading this thread it has occurred to me Ive never drain my water seperator. Simple reason my light has never came on. Is this normal? Ive got a 2010 with about 21k mi. I run a diesel clean in almost every tank and have had the all filters replaced on schedule. Im started doing the normal 10k mi changes but Im going to up it to the 5k mi plan due to reccomendations from other members. Please tell me this is normal!
STM
Old Nov 2, 2010 | 11:38 AM
senix's Avatar
senix
STM
I have never had mine come on either. All that really means is you have been getting good fuel or the amount of water has not been enough to trigger the warning.
Still need to drain it monthly.
Old Nov 2, 2010 | 12:18 PM
StanleyZ's Avatar
StanleyZ
STM
I think a lot of us drain the fuel monthly. The theory is that ingested water in the fuel system can turn into a major disaster pretty quickly on these trucks, and once the light comes on it may be too late. I think a lot of folks on here believe that these motors want a lot of love and if you give it to them they will give it back. So far it's working for me but then I'm only at 27K.
Old Nov 2, 2010 | 03:33 PM
EasyRider6's Avatar
EasyRider6
I had problems opening the valve right after I bought my (first diesel) truck at 26k. I read that someone broke off the lever, so I took it in to the dealer for the first oil/and fuel filter change just in case. Service guy said there was "lots" of water.
As soon as I got home I checked it myself and it was easier to get it open and I opened/closed it about a dozen times, that seemed to help loosen it a bit. Now I check it monthly and enter the checks into the Ford Owner web site along with all other maintenance. I use the same clear water bottle every time I drain the water separator. Since I wasn't sure what to look for the first time, I put a spot of water in with the diesel and it was pretty obvious. It separates to the bottom pretty quick.
I've checked it three times since then and haven't seen a drop of water. I use Motorcraft or Diesel Kleen Cetane additive every fill. I leave the valve open for about thirty seconds which is about 8 oz of diesel for me. I've read some threads where little to nothing comes out and it's usually been either something clogging the drain tube or gelled up goo inside the housing.
Hope this helps.
Old Nov 16, 2010 | 12:18 PM
kjstanger's Avatar
kjstanger
Having some concerns myself, I drained my water seperator about six weeks ago and two weeks later the messege came up, so I drained it again, two weeks later messege came up again, so I drained it again. This has become the norm for me. I am within a thousand miles of the 40k schedule service, should I wait and drain until then or should I bite it and take it in now? I really only want to take it in once. I've read other posts about this and some people had to replace the lower fuel filter before the messege stopped. Advise please.
Thanks.
Old Nov 16, 2010 | 12:40 PM
EasyRider6's Avatar
EasyRider6
kjstanger:
Are you getting any water when you drain? From what I've picked up from these forums you might have a sensor going out, you might have fuel gelled up in the lower filter housing. I think the sensor is pretty easy to replace yourself. Not sure about gelled fuel in the housing. Probably the most important thing I've picked up is don't let it go too long. Water in the fuel can lead to huge $$$.
Old Nov 16, 2010 | 01:23 PM
kjstanger's Avatar
kjstanger
Originally Posted by EasyRider6
kjstanger:
I will drain again and let sit for a while to see. Will let you know the out come.
