Planning this weekend, don't know when or if it has ever been done.
One other thought: the temperature control ****? Mine went bad and the symptoms were temperature fluctuations. If you look under my user name and threads that I started, one of them is about heat and it landed up being the ****. $30 at Ford and 10 minutes of work.
I have a 99EB doing exactly the same thing. Being EB I have the climate control.
This summer I did the blend door repair thru the glove box. There no way the door broke. It's solid stainless steel. The AC works like a raped ape. But thats asking the blend door to be closed. Whats makes the door open with the climate control?
