View Poll Results: what color hid's?
5000
36.00%
6000
52.00%
8000
12.00%
Voters: 25. You may not vote on this poll
hid conversion kit
Old Dec 7, 2010 | 10:58 PM
86F150302's Avatar
86F150302
Originally Posted by 97f351
is this the correct hid kit for a 96-97 f350
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
That is the Slim ballast kit. Its $10 more than the standard size ballast.
Here is what you want
Like I posted above.
35 watt
9007 bulb. 9007 Hi/lo if you want to use highbeams too.
6000k is what I recommend (Whatever color you want)
Everything else blank.
I installed 2 DDM HID kits this past month. 1 for an 07 Tahoe and 1 on a 07 Mustang. Also installed sequential tails on it.. They are sweeet.
Old Sep 20, 2011 | 01:59 AM
anna1985beatufy's Avatar
anna1985beatufy
firstly ,i never don't like your post. you did a good job .
for your truck ,9007 is right for your truck.
but the color ,you can chose a favor color. but i think the sunlight color is best ,it is 6000k,.
last year i chose a 6000k,55w VVME hid for my high beam ,thank good ness. there are no issues now .
good luck to you
Old Sep 20, 2011 | 02:03 AM
86F150302's Avatar
86F150302
Originally Posted by anna1985beatufy
f
Negative. 4300k would be closest to sunlight. 5000k is pure white. 6000k is white with hint of blue. I have installed 3 6000k setups. I have 8000k but will be running 5000k in my projectors.
Old Jul 15, 2012 | 05:54 PM
selym22's Avatar
selym22
I have a 95 f150. I put 8000K hids in about a year ago. The kit was basically plug and play, it uses one of the plugs from the stock headlight, then it needs to be connected to the battery, and grounded twice. The only problem I have experienced is my high beams don't work, haven't since I installed them. Does anyone know how to fix that?? (No high beams or flash-to-pass)
Old Jul 15, 2012 | 07:03 PM
wicat3's Avatar
wicat3
I dont have any on my truck but I had them on my old ranger pickup and I loved them. Got them from ddmtunning for a great price. I was going to do a set on this truck but decided to do a harness upgrade. Anyway I did 8000k but could have went with the 6000K and be fine
Old Jul 15, 2012 | 08:20 PM
BigBlueOx's Avatar
BigBlueOx
It sounds like they sent you a harness for 9004 lamps. I put a harness and high wattage halogens in my fathers 01 SD and I had the same problem.
I depinned the sockets and wired them for 9007 and they were good to go.
BadDogKuzz
88
Sep 29, 2020 08:56 PM
Whitey Ford
Oct 2, 2015 05:35 PM
snowdog79
2004 - 2008 F150
Dec 14, 2010 08:08 PM
Milwaukee,WI
Aug 25, 2009 06:51 AM
