No, I never found a wiring diagram. I think I've made my own from figuring where the wires went. I also found some info about one being put into a GM product that gives a little insight.
I'm really worried about using it. Not because there is anything wrong with it, but I was going to put in my son's 79, because he has a 4.10. But I have decided to go with a 3.54 rear end to lessen the trouble of a on the road breakdown, and no one knowing what to do.
I would be intersted in whatever you know!! I know nothing about these units so pardon my stupid questions
What % overdrive is it?
Do you know if these were made in overdrive and underdrive?
I think "Hone-O-Drive" was manafactured in Redding, do you know if this may be a decendant of the "Hone-O-Drive"?
Does the output shaft of the automatic trans go directly to the unit or is there a adapter hub? I am trying to figure out how difficult it would be to mate it to something other than a C6
Have you looked inside this unit to see how it works?
if yes I would be interested what shifts it, band, clutches, cone, slider like in a manual trans? and if it has 3 or 4 planetary gears
Hone was an insert in the drive line. Had a short drive shaft in, and then one on to the rearend. Similar to a detached t-case. It had a manual shift lever.
This is very similar in looks to a Gearvendor. Replaces tailshaft housing, and bolts on direct to a C6. Has an oil line from the trans to the OD unit. Has a park interlock cable to disable OD in park, so vehicle won't roll.
As for how, why, type of shifting, %, have no idea.
If you don't mind the paying the price, I'd watch Ebay.
Note. Redding CA. seems to have been a hot bed for OD units;
There was Hone, American Overdrive, Mitchell OD or UD stand alone like the Hone. Gearvendor says they are not connected, and US Gear is all gear drive, so doesn't need a interlock cable.
Steven, go to Ebay and look up overdrive in the auto parts section. The is an American OD unit for a turbo 400, an a couple of Doug Nash units less the adapters from what the pictures look like. Bob
Thats what got me started looking for info, I have not gotten a reply from the seller on the OD ratio, I am a little worried if it really is made out of existing transmission parts it is likely a 45% overdrive(if it uses a planetary set from from a TH400 or TF727)
I am looking for a 30% od, GV are 22% this is going in a car so the DN is a little big, no place for you feet in the back seat
I've never heard of a 45% OD. That seem mighty steep. That means a 3.00 rear end would be = to a 1.35 in OD: a 4.10 would be = to a 1.84. Also. American, Doug Nash, Gearvendor all mount about the same. They all add about a foot to the trans length. Bob
As for the .45 overdrive, the T-56 in 94 up camaro, corvette, viper... is .5 in second overdrive. They run most of them with 3.23 to 3.73 rear ends, too. So it is done (or very nearly) by the OEM's.
Got a reply back from the seller he turned it an checked the rotation, it is about a 50% overdrive(probably TH 400 gearset it would be 48%), that is a bunch!!! you are going to need to shift this thing, with 4.11 you run about 110mph at 6000rpm, just right for the quarter mile, but with 48% OD you run 80mph at 2300, not many engines make power from 2300 to 6000, except the oems mentioned above with engine management, probably a better application for an underpowered truck pulling a load at 60mph and running empty at 80 in OD
