Offroad & 4x4
Got a transfer case question
Old Oct 30, 2010 | 06:52 PM
chitlin1's Avatar
chitlin1
What'll cause your transfer case to get stuck in 4 low.The linkage is moving under the truck.The lights in the dash go out when you go back to 2 wheel drive.I'm sure it's an internal problem,just not sure what.Anybody got any suggestions?
Old Oct 30, 2010 | 09:31 PM
dragogt's Avatar
dragogt
Shift fork or collar linkage maybe broken..
Old Oct 31, 2010 | 06:01 PM
alpha/omega's Avatar
alpha/omega
what t-case? Im assuming BW?
Old Oct 31, 2010 | 09:44 PM
chitlin1's Avatar
chitlin1
type
Yea,it's a BW.
Old Oct 31, 2010 | 10:15 PM
captain p4's Avatar
captain p4
That's your problem. Swap an NP205 in and you're GOLDEN
Old Nov 1, 2010 | 01:41 AM
hav24wheel's Avatar
hav24wheel
A 205 is not always the answer. Personally a 205. Wouldn't work in my 94 without changing my long tube heAders to something different.
My guess would be a oil pump failure.
Old Nov 1, 2010 | 09:49 AM
kjett's Avatar
kjett
It might be a combo of things. I know when the oil pump in my BW failed, it did the same thing but when i pulled it apart it broke the fork as a result of the broken pump spinning around and causing more damage. Either way, if you pull it apart, replace the pump as good measure.
buzter
Modular V10 (6.8l)
Feb 20, 2012 03:44 PM
B1GKAHUNA
Mar 25, 2007 10:27 AM
djmac
Jul 1, 2004 01:11 AM
Tex311
Bronco II
Jan 5, 2004 08:30 PM
proeliator
Offroad & 4x4
Jun 11, 2001 08:36 PM
