HELP: Power Steering Failure
Old Oct 30, 2010 | 04:25 PM
cowboylelle's Avatar
cowboylelle
Hi guys!
Talk about bad luck: Sold my -99 F250 SD PowerStroke Diesel Truck and the guy who bought it just called me (5 hours later) and said that the Power Steering failed - also the brake system went bad in that he has to push hard to break. I asked him to check the oil level and he came back and said there is a big oil leak and that the container is almost empty. What do you think could be the most possible place for a leak? A hose? A gasket? A pump? Where should we start to look? Any tips are appreciated. Best regards,
Lennart
Old Oct 30, 2010 | 04:47 PM
binuya's Avatar
binuya
First, check the hoses. One makes contact with the valve cover? (I think). It will rub through. Fairly common. But definitely check hoses first.
Old Oct 30, 2010 | 06:14 PM
SlowGTA's Avatar
SlowGTA
Sorry about the bad luck!
As far as the brakes, the power brake assist on the Diesel trucks is provided by the power steering pump. When you get the power steering fixed I'll bet the brakes will be fine.
Old Oct 30, 2010 | 06:29 PM
F350-6's Avatar
F350-6
Tell him about FTE. That's probably the best thing you can do for him.
Old Oct 30, 2010 | 07:35 PM
SpringerPop's Avatar
SpringerPop
Where the pressure line passes by the driver's shock tower is a common place to wear through the hose.
Because it is a hydroboost unit, as has been said above, when there is no hydraulic pressure for the power steering, the "power" in power brakes goes, too.
Pop
