Advice Please!
Old Oct 30, 2010 | 11:03 AM
gixer311's Avatar
gixer311
Advice Please!
I thought I had my bed shake figured out(when going over bumps at speeds under 50), but it turns out I don't...so far I have tightened all bolts, replaced rear shocks with Monroe Reflex, took out rear 1-5/8" block, tried the Sulastic rear shackles, played with the tire pressure, and put 160lbs of sand in the back. The tires are pretty much new, they are Cooper Discoverer ATR's (255/70/17). This is a 04 STX with only 44K on it. I am now contemplating Firestone air-bags and Bilstein 5100 shocks (for front and back). Will I just be wasting my time and money with this???
(I have searched for weeks with no solid info)
Old Oct 30, 2010 | 11:29 AM
danorules's Avatar
danorules
it is a waste of time. the beds shake a bit. no harm in that. also you have checked all the bolts and connections, so the bed is secure and safe. my bed shakes also, and has no problems. i just learned to live with it. my theory is that it is not the suspension, but the bed itself. these f-150 beds are so much deeper/taller than previous years. i think that there is just less strength in the bed walls causing a shake. not to say that the beds are weak, just not properly gusseted or braced to control or stop the bed vibration. but that is just my theory. i could be way off
Old Oct 30, 2010 | 05:18 PM
gixer311's Avatar
gixer311
I guess I just don't understand why some of these have the god awful shake and some do not...there's about four f150's where I work and I was told that none of them have this shake.
Old Oct 30, 2010 | 05:52 PM
Coskid's Avatar
Coskid
Until joining this forum I never heard anyone talk about their bed shaking on the 150's.
Old Oct 30, 2010 | 06:00 PM
daveshomeservice's Avatar
daveshomeservice
The bed is bolted directly to the frame,the cab is mounted to the frame through huge rubber body mounts. when you look in your side mirrors,and see the bed shaking,you are seeing the difference.
Old Oct 30, 2010 | 07:07 PM
danorules's Avatar
danorules
true, however some of the f-150s have a more pronounced shake than other trucks
Old Oct 30, 2010 | 08:44 PM
gixer311's Avatar
gixer311
More pronounced is mine to a T...I just had it inspected and showed the mechanic and he was baffled. I was curious if there was anyone out their that has the same problem as me and tried either the air bags or bilsteins and what the outcome was. If not I am just going to do it. I am pretty much at the point if I can't figure this our or even lesson it, I will start looking for another ride...its just that annoying. I could probably adjust to the bed giggling, but being that it affects the cab as well is the most annoying part about it. Don't get me wrong, this is a smooth riding truck, but I am starting to regret trading my 89 f150 in for it.
Old Oct 30, 2010 | 11:13 PM
efx4's Avatar
efx4
It is normal for the beds on these trucks to have some shake to them. It actually helps to absorb some of the heavy bumps to improve ride quality. I've worked on all the other brand of trucks at work and they aren't much different when looking out the side mirror. You should has some piece of mind knowing that you checked all the crucial parts of the bed though.
Old Oct 31, 2010 | 12:12 AM
Quack Addict's Avatar
Quack Addict
Mine used to shake noticeably also. Once I added the shell I noticed that it went away.
Old Oct 31, 2010 | 07:40 AM
Coskid's Avatar
Coskid
Yeah I have been checking for this for the last 3 months and mine just doesn't do it so I consider myself fortunate because so many complain about it. I have even gone so far as to pull out the 2 swing tool boxes I have mounted at the rear of my bed and it still doesn't shake.
Old Oct 31, 2010 | 08:00 AM
danorules's Avatar
danorules
i dont believe that any suspension mods are going to help. if you notice that quack addict lost his shake when loaded with a cap. the top of the bed is what is shaking, so the cross bracing of the cap stops that. therefore i believe that the mods you are planning are just a waste of money. you should try a load secure bar. one of those ratcheting cross bars, just put it in the bed towards the rear and up high and that may help. also it will be less expensive than airbags, and it will serve a second purpose if it doesn't help.i think they go for $35 at harbor freight. just my $.02
Old Oct 31, 2010 | 08:01 AM
danorules's Avatar
danorules
or fold in your mirrors, then you won't see the bed shake.lol
Old Oct 31, 2010 | 12:55 PM
Coskid's Avatar
Coskid
I wonder if the roll-up cover I put on my truck does the same for cross bracing. This might explain why I never saw it shake because the cover was installed 1 day after owning the truck. I actually bought it a few days before I picked the truck up so that it would be ready to install right away.
Old Nov 1, 2010 | 04:53 PM
gixer311's Avatar
gixer311
Wonder if this type would help...
Old Nov 1, 2010 | 05:07 PM
1bad67sbf's Avatar
1bad67sbf
i would have to say no due to it has no cross brace in the bed from what i can see. mine rattles but thats the tailgate bushings need to be replaced
