Ignition systems
Old Oct 30, 2010 | 10:27 AM
parr4's Avatar
parr4
Ignition systems
Using the OE Dspk2 on my truck. Always had contamination problems with the cap electrodes and the rotor. Switched to Brass which definitely helped, but I'm wondering if a better system is available. Once it won't start now I know again, it's time to go clean-up the electrodes. If this was the old points system I'd know the condenser was 'weak', but.....
Old Oct 30, 2010 | 10:45 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You could spend more money, but my opinion is you already have the best to use.
Old Oct 30, 2010 | 01:39 PM
Harte3's Avatar
Harte3
Main
Might get a little improvement in the ignition by using the GM HEI module with the DS2 dizzy otherwise you might consider a MSD 6 or Mallory HyFire 6a box. A Summit Street and Strip might be a better buy though. Either way you might end up with more bragging rights than actual performance over the stock DS2 box.
Old Oct 30, 2010 | 02:59 PM
rikard's Avatar
rikard
If the cap and rotor are getting contaminated check the PCV system. The distributer shaft bushing, seal, or shaft might be worn too. None of my Fords have had this issue but my slant six did and the seal was gone. When my PCV clogged on a GM 4.3 it forced oil vapor into the cap.
regards
rikard
