Ok and I've done the hutch and harpoon mods still having the same problem. I'm going to try cleaning the ebpv tube and change the uvch. Does any one know of a set of used injectors or even a set of stage 1 injectors for sale.
I thought about buying a upgrade spring for the regulator. Any suggestions.
I went with this Billet FPR Housing from Dieselorings.com. An extremely high quality product. I used the black spring, which is the strongest. Fuel pressure at idle was 69 to 70 psi. When installing I noticed the FPR poppet valve seal was worn out. So I got an FPR rebuild kit. The poppet valve seal is special made and an o-ring will not work. FPR Rebuild Kit also available from Dieselorings.com. Now fuel pressure is between 74 and 75 psi at idle and doesn't drop below 65 at WOT. I do have a Walbro GLS 392 fuel pump though.
Edit : Before doing any shimmig or spring replacing in the FPR you need a fuel pressure gauge. I managed to get the weakest spring cocked when installing and the fuel pressure pegged my 100 psi fuel guage. Without a gauge I would have not known.
