compressor switches on
Old Oct 29, 2010 | 10:21 PM
octaneforce's Avatar
octaneforce
when i put my heat onto "defrost" or "mix" the compressor will click on. it doesnt click on if i just go to "floor". also, i have no selection between normal and max a/c. it just blows equally on both settings. is my switch shot? 1992 f150 i6. its an XLT model if that matters.
Old Oct 29, 2010 | 10:48 PM
White 97 xlt's Avatar
White 97 xlt
It's designed to run the a/c compressor in defrost and mix settings....
Max air does not blow more, it recirculates the air....
All is normal!!!
Old Oct 30, 2010 | 02:05 AM
wickedklown83's Avatar
wickedklown83
that plus i was told its to keep the compressor frome freezing up
Old Oct 30, 2010 | 09:42 PM
octaneforce
okay thanks alot. last winter my compressor didnt work so im just not used to hearing it click on.
Old Oct 30, 2010 | 11:30 PM
skyfox10's Avatar
skyfox10
what is to keep the compressor from freezing up?
Old Oct 30, 2010 | 11:42 PM
White 97 xlt
It does help with that, but the main reason is to remove moisture in the air.. As in windows won't fog up as bad..(if the A/C is working like it should be)
