advanced timing. quick questions
Old Oct 30, 2010 | 07:19 AM
xc4jokestomper's Avatar
xc4jokestomper
what all do i need to do this? im trying to find the articles that have the step by step write up but i cant find them. what all do i need? i know i need a remote start. how do i check the timing? do i need a timing light? anything else other than household tools? im making a run to harbor freight here later and was just wondering.
Old Oct 30, 2010 | 07:20 AM
xc4jokestomper
oh one more thing. can i advance the timing with the stock coil? i havent upgraded it yet.
Old Oct 30, 2010 | 07:40 AM
lew52's Avatar
lew52
The coil is fine you just need a timing light , remove spout , advance timing to 12 btdc , replace the spout take it for a ride , if you hear any pinging then you went to far , 12-14 is about the norm , you just got to play with it ,,,,Lew
Old Oct 30, 2010 | 08:32 AM
rikard's Avatar
rikard
The stock components will handle the advanced timing if they are in good shape. Many of the caps, rotors, and wires sold by discount stores may not be as good as OEM. I would suggest spiral core wires and brand name cap and rotor with brass contacts. Increasing the plug gap can help when advancing the timing too.
regards
rikard
Old Oct 30, 2010 | 11:50 PM
skyfox10's Avatar
skyfox10
Here is an excelent walkthrough.
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
The first have talks about replacing ignition components. But if you skip down, it shows how to set timing, complete with pics.
