Tire Pressure
Old Oct 29, 2010 | 07:57 PM
Major Marvin's Avatar
Major Marvin
Tire Pressure
Curious what pressure/size tire everyone is running.
I myself am running 285 75 16 LT @ 65 pounds front and rear Thinking of dropping them down to 50 pounds
With a full heavy load I would be tempted to run max pressure.
With the combined experience here, perhaps we can all benefit?
Old Oct 29, 2010 | 08:19 PM
tjbeggs's Avatar
tjbeggs
I run 285/75R16's at 65 which is max tire pressure. Max pressure for my truck mostly empty provides the best tread wear and life. I don't notice much of a ride difference with I drop to 55 psi and I won't run any lower than that.
redman84's Avatar
redman84
There's a lot of difference in opinion on this matter. With 235/85 16s I used to run the door sticker specs - 55 front 80 rear. 80 is way too rough for daily driving. I swithced to 55 psi all around and it was just fine. Great tread wear, smooth enough ride, and good mileage. I stuck with that after bumping up to 265/75 16s. In trying to troubleshoot my terrible mileage problem I bumped them up to 65 psi all around this week. I can definitely tell a difference in ride quality after only like 75 miles. It's rougher but if it helps my mileage then so be it. Some people put a stripe of white shoe polish, finger nail paint, soapstone, etc across their tread and then adjust the pressure til it wears evenly. Sounds pretty logical to me.
Old Oct 29, 2010 | 09:14 PM
fordpride's Avatar
fordpride
i use the shoe polish trick i run 265/75/16 TOYO OPEN COUNTRY AT 12ply i run 52 front and 50 rear unloaded when loaded i bump them up to 65 front and 80 rear
Old Oct 30, 2010 | 02:54 PM
Major Marvin
Sounds good folks. I'm going to run them at 65 all around for starters and see how it goes. I have the BFG KM2 Mud Terrains in 285 75 16 LT. I believe their max pressure is 80 psi.
bluefin
6.7L Power Stroke Diesel
15
Oct 24, 2014 08:48 AM
MEDF150
15
Oct 4, 2010 04:16 AM
Rick Cargo
Sep 8, 2010 06:10 PM
ClatonK
Jan 4, 2006 04:21 PM
ktmguy70
Sep 15, 2003 09:41 AM
