Copper head gasket, how do install??
Old Feb 25, 2003 | 07:55 PM
Reuel's Avatar
Reuel
I just fired up my $5,000 351W stroked out to 393 and guess what? I have an antifreeze leak in one of the head gaskets. Its a high compression engine and i had to use copper gaskets. I guess i am asking the question a little late but does anyone know how i was SUPPOSE to properly seal the head gaskets? I am sick thinking about all the work i put into it and now have to yank everything back out again. Thanks for the help.
Old Feb 25, 2003 | 08:57 PM
bigred78's Avatar
bigred78
I installed copper head gaskets too last year and had the same problem. I decided to go with the regular felpro head gaskets. Go to this website. http://www.scegaskets.com/preparation_40.asp
Good Luck
Bob
Old Feb 26, 2003 | 09:45 AM
beartracks's Avatar
beartracks
have you retorqued them yet? It's a requirement after it's run in.
Old Feb 27, 2003 | 02:45 AM
Big F250's Avatar
Big F250
on copper head gaskets you have to put rtv on both sides of the gasket around all the water ports and bolt holes that protrude through a water port. Do yourself a favor and junk the expensive copper gaskets. Get the highest quality felpro gaskets and you'll be problem free.
Old Feb 28, 2003 | 03:43 PM
BlueOvalRage's Avatar
BlueOvalRage
FelPro part# 1011-2 They'll seal it up every time and are compatible with high compression.
Old Feb 28, 2003 | 06:56 PM
TMI's Avatar
TMI
Richard Clark at Clark gaskets says not to run copper gaskets with out O-ringing the block and/or head.
He also said if you are less then 13-14:1 compression you don't need copper gaskets.
Clark Gaskets seems to big in the drag racing scene.
I personnelly have not seen copper head gaskets work to often.
But I also don't know how they are being installed. I am currently putting copper gasket on a race engine, basically because they are cheaper then the Fel-Pro gasket, and when it get freshened every 15-20 races, gaskets get expensive. We are O-ringing the block.
Old Mar 3, 2003 | 12:14 AM
TorqueKing's Avatar
TorqueKing
That gasket that Rage is talking about, the 1011-2, I've been running those for a year now, and I have been very pleased with them. I did an engine swap this winter, and after pulling the old motor apart, The 1011-2s on the motor were sealing easily. One thing about them that I just realized is that there is only one water passage drilled for them at the ends of the block, so I took a drill to the gasket to open up all the water passages. Couldn't find any literature on doing this, but it's working very well. I bought mine for $29.95 a piece through Jeg's. TK
BigBlocker0248
24
Jan 18, 2016 08:37 PM
Runningaddict
Dec 31, 2015 02:36 PM
Island'r
Dec 21, 2015 08:37 PM
bruno2
18
Jun 10, 2012 04:47 PM
mulot30th
Oct 7, 2007 03:04 AM
