replacing the outer wheel bearings
Old Nov 3, 2010 | 08:16 PM
74redone's Avatar
74redone
Two new tire and still makes the same noise from the rear end. Checked the oil again and it was a little low. I added some oil and took the truck for a drive. It seemed to help but it is still making the whine just not as loud. The plug had a thick black grease on it. It didnt feel like there was any metal in the black grease on the plug. So what do you guys think? Start with the outer wheel bearings? the noise does seem to be more on the passengers outside corner. Should I take the cover off and clean out the case and refill with new oil?Any input will help! Has anybody put Amsoil in the rear end? I've been told it helps quiet down the gears. Thanks!
Old Nov 3, 2010 | 10:13 PM
Coskid's Avatar
Coskid
I would change out the oil in the rear diff before jumping to the outer wheel bearings.
Old Nov 3, 2010 | 11:05 PM
Bdox's Avatar
Bdox
If you go that route, place some strong magnets inside the housing to collect any future steel or iron debris.
Did you put it on jacks, chock the front wheels, and use a stethoscope to isolate the sound?
Old Nov 4, 2010 | 04:20 AM
74redone's Avatar
74redone
no I have not, but that is a good idea! Thanks!
Old Nov 4, 2010 | 05:28 PM
74redone's Avatar
74redone
how do I view the TSB's? I found them but how do I read the info that they give? Sorry to be a pain in the butt!
Originally Posted by Sako 75
Not a difficult project. Other costs you need to consider.
2 quarts of 75-140 syn. gear lube (check the tsb). $50.00
Friction modifier. $18.00
Black RTV. $5.00
Consumables. $5.00
There is another tsb that discribes rear diff. whine. I will try to locate it for you and re post. It would be a good idea to narrow down the source of the whine before you start throwing your time and money at it.
Here is the tsb for the "05 model. I will continue to look for the "07.
05-23-3***REAR AXLE NOISE REPAIR
Not finding a tsb for the "07.
Old Nov 4, 2010 | 06:12 PM
Sako 75's Avatar
Sako 75
Go to the full text TSB drop down and search for your symptom. Your not being a pain, we are here to help.
Old Nov 7, 2010 | 10:23 PM
74redone's Avatar
74redone
Okay I changed both sides on the outer bearings of the rear end. still same noise! There wasn;t any metal in the housing when I pulled the cover off. There was like a dark gray coating on the the internal parts. Any ideas would be a great help. I'm almost to the point of taking it in to the dealer. Just really dont have the extra right now o pay someone that I can do for free.
Old Nov 8, 2010 | 06:38 AM
Djack04F150XL's Avatar
Djack04F150XL
Check on a local shop that specializes in drive lines. There are some shops in my area that do very good work for a fraction of dealer cost and they use OEM or better parts.
Old Nov 8, 2010 | 12:40 PM
perk_dp's Avatar
perk_dp
8th Gear
that noise is probably the drivers side front. when the front wheel bearings start to go bad they make a whiney roar that's hard to tell where is coming from
Old Nov 10, 2010 | 11:04 PM
74redone's Avatar
74redone
Well truck went to the shop today. The pinion bearing is bad. Which I'm lucky enough to have the 9.75 axle so that means no aftermarket parts. The bearings had to come from the Ford dealer. $800 later and I will be back on the road again with a quite truck. The truck only has 66,000 miles on it! Thanks to everyone that responded to this thread and gave the time to try to help.
busdriver47
Apr 30, 2019 03:11 AM
Peavey1986
Mar 26, 2017 08:39 PM
anthonym92
20
Nov 3, 2015 08:51 PM
mattri
Jan 10, 2014 06:48 PM
J.McConnell
13
Apr 21, 2009 12:19 PM
