Horn does not work
Old Oct 28, 2010 | 05:51 PM
tutley's Avatar
tutley
Horn does not work
First time poster needing a little help. 1990 Ford F250 horn does not work. Replaced the horn because it was bad and it still did not work. Checked voltage at the horn and I'm getting 11.6 so I replaced the horn relay, still no good. So I am at a loss, wondering if there is a ground somewhere I need to check.
Thanks for any help!
Old Oct 28, 2010 | 07:15 PM
TexasGuy001's Avatar
TexasGuy001
If your getting power to the horn and it still doesn't work, then I would say the horn is no good. Try running a wire directly off of the battery to the horn and see if it works.
Old Oct 28, 2010 | 07:40 PM
tutley's Avatar
tutley
I bought a new horn and tested it, it works fine. I read somewhere that I should be getting between 12 and 14 volts to the horn, this really has me
Old Oct 28, 2010 | 07:49 PM
juni88126's Avatar
juni88126
it sounds like you are having a ground problem. Clean the rust and paint from around the area were the horn bolts to the body.
Old Oct 28, 2010 | 08:08 PM
tutley's Avatar
tutley
Ok, I don't know much about this but the package says this horn does not require a ground. Even tells you to hook it up before you install it to test it. I have had it hooked up not installed and grounded, not grounded and it does not work. Installed and does not work.
Old Oct 29, 2010 | 03:18 AM
TexasGuy001
So no matter what you do even using a wire directly to the battery the horn does not work?
Old Oct 29, 2010 | 07:18 AM
tutley's Avatar
tutley
NO. I have tested the horn running wires straight off the battery to the horn and it works
Old Oct 30, 2010 | 06:43 AM
TexasGuy001
I guess I missed that part about it being tested. Have you tried cleaning the inside of the connectors that it plugs into? That often works. You can get electronic terminal/connector cleaner in a spary can at most auto stores.
Old Oct 30, 2010 | 07:14 AM
91chevywt's Avatar
91chevywt
If you have power going into the horn, and the horn works separately, it has to be a ground problem. A horn is a simple electric motor. Needs power and ground. Since you say it has no ground, it must ground to where it bolts to the vehicle. Make sure it's bolted to a solid piece of metal. You may need to scrape off a little paint to get proper contact. It should also have some type of star washer incorperated into one of the bolt holes, if it in fact has no ground wire.
66_F100
60
Dec 17, 2019 06:23 PM
stanfil82
Apr 30, 2014 02:02 PM
panochote
1997 - 2003 F150
23
May 11, 2008 04:44 PM
Justin460
Sep 6, 2007 06:38 AM
ullearn1
Electrical Systems/Wiring
13
Nov 29, 2006 11:13 PM
