Hi just recently bought a 67 428 that was originaly in a 67 tbird, its in a 1970 f600 now, My questions are will a 352 truck 3 speed bellhousing bolt to a toploader four speed, and will i have to change the flywheel that was used in the f600?
the toploader is a close ratio out of a 64 galaxie, yes i measured the stroke and is 4" has c6me on pass side of block and 22 DIF on drivers side has a bunch of holes on back side of flywheel where balancing was done
OK good, just check the depth of the bell--truck bells are 1/4" deeper, not sure on your 352 bell. The pattern should be the same, the Ford "butterfly" pattern.
