oil ?'s
Old Oct 27, 2010 | 10:07 PM
danger-ranger93's Avatar
danger-ranger93
oil ?'s
ok well my *new* '96 is comming up on its first oil change under my ownership, it has 166,*** miles on it and i have heard rumors on bad things happening when going from conventinal oil to synthetic with more than 100,000 miles on the clock.
i ran valvoline max life in my '87, but that is what it was running when i bought it, so now my question.
with that many miles if i switch to the max life in this motor will i get one of those "oh ****" moments after the change?
i have no problem with convential oil but the synthetic in the '87 seemed like it made the truck run much better..
just looking for a REAL answer..
Old Oct 27, 2010 | 10:12 PM
86F150302's Avatar
86F150302
Everyone has different opinions on this. I personally would swap to Mobil 1. I put M1 in my truck, dads F150 and moms toyota.
Old Oct 27, 2010 | 10:23 PM
timbersteel's Avatar
timbersteel
Just my 2 cents, Stick with conventional oil. I run rotella 15w-40 in both of mine. When it get's really cold, I switch to 10w-30 rotella. I had terrible results switching to syn. Sounded like ball bearing rolling around in the engine. Went back to conventional and hasn't done it again. Have also heard of seals leaking on older vehicles with high miles that hadn't leaked before, only when they switched to synthetic.
But as said before, everyone will have different opinions on this. If money isn't an object, you can give it a shot. $4+ versus $2+.
Old Oct 28, 2010 | 01:06 AM
pnp522's Avatar
pnp522
I switched to synthetic in my 93 after a re-build. My 70 Econoline went 275,000 on conventional. Regular maintenance matters more than synthetic or conventional.
Old Oct 28, 2010 | 02:26 AM
86F150302's Avatar
86F150302
Leaky Seals & Synthetic Oil Leaks?
https://www.mobiloil.com/USA-English...ollection.aspx
Couple links I found for the "synthetic causes leaks" topic.
http://www.synthetic-motor-oil-chang...ynthetic-oils/
Old Oct 28, 2010 | 03:32 AM
TexasGuy001's Avatar
TexasGuy001
I would just run conventional Valvoline or the Max life if it has alot of miles on it.
Old Oct 28, 2010 | 08:51 AM
JMC302's Avatar
JMC302
What are the differences between regular oil and rotella? I have seen people talk about running rotella in their gas trucks but I am not sure why.
Old Oct 28, 2010 | 09:27 AM
Hitokori's Avatar
Hitokori
i run valvoline vr1 20w50 >:P lol
Old Oct 28, 2010 | 10:27 AM
hammerhead90's Avatar
hammerhead90
I've run the Valvoline synthetic blend for 7k miles and two oil changes now. It's worked for me. The old oil doesn't look too bad even after 4k miles
Old Oct 28, 2010 | 10:40 AM
pnp522's Avatar
pnp522
Rotella is Shell's brand of oil made for diesel engines but it is approved for gas engines too.
Old Oct 28, 2010 | 12:47 PM
rla2005's Avatar
rla2005
Rotella still has a fair amount of zinc in it. Zinc is a critical lubricant for non-roller camshaft equipped vehicles. Most oils designed for gasoline automotive use are cutting back on zinc in the formula.
Personally I use Red Line synthetic oil in all my vehicles (4) regardless of miles on the engine. I acquired my current '92 F350 w/5.8L engine about 2 years ago with 150k miles on it. No ill effects after I put in Red Line such as leaks, noises, increased oil consumption, etc. Red Line rates their oil to protect for up to 12 months or 15,000 miles. I change the oil filters in between my annual oil changes. I save the old oil for use in the chainsaw as bar/chain lubricant.
Old Oct 28, 2010 | 03:09 PM
danger-ranger93
i think i may swap to the synthetic when i change it out. really i don't see the problem with it. My truck has 167,*** miles as of today, would you consider that a lot of miles?
Old Oct 28, 2010 | 03:19 PM
lew52's Avatar
lew52
They wont explode till 168,000 so your good ....if you take care of them they will go well over 200,000.....Lew
Old Oct 28, 2010 | 04:40 PM
cjben's Avatar
cjben
I believe it is a personal decision. I have switched several of my vehicles with high miles over to synthetic and never had a leaking problem. I change oil twice a year now,spring and fall,never had a problem.
Old Oct 28, 2010 | 05:47 PM
rla2005's Avatar
rla2005
Lew...you crack me up!!
