AIH Mod?
Old Oct 27, 2010 | 08:24 PM
tritonman2001's Avatar
tritonman2001
AIH Mod?
I see that alot of you guys have this mod listed, and I would like to know what it is and how you do it. Thanks in advance.
Old Oct 27, 2010 | 08:28 PM
timmyboy76's Avatar
timmyboy76
On the "return" charge tube, just before the spider collector assy, you'll see a plug, with a black and red cable from it. Remove that unit..(air intake heater/AIH), then go to Autozone, and getta dodge cummins drain plug, believe pitch is 22x1.50, for 12 buks, then install it. Remove the black cable and red cable that hooks to the relay, but make sure you re-install the blue wire at relay.
Old Oct 27, 2010 | 08:32 PM
Shake-N-Bake's Avatar
Shake-N-Bake
There is an electric heating element in the cool side of the intercooler pipes just before it splits to each cylinder head. The purpose of the heater is to heat the air on cold mornings. Seems a bit silly if you ask me because that air was just cooled by the intercooler and now they want to heat it up again? Go figure.
At any rate, that heater element can be removed and a fitting put there to tap off and connect a hose for a boost gauge. That is what most people do. If you don't have a boost gauge, you can still take out the heater and put a plug in that hole. Some people think the heater restricts airflow and removing it increases flow. Not sure if that is true or not but it seem plausible. Here is a pic.
File Type: pdf
Ponyboychris's Avatar
Ponyboychris
Pretty simple mod. It's removing the Air Intake Heater element from your intake path. You must have a loate '99 - '03 7.3. The early '99's didn't have an AIH.
Here's Clay's plug. It's very nice. Riffraff Diesel: RDP AIH Tapped Fitting
Here's a write up on how to remove the AIH that I copied from another site:
Remove the red wire (hot) from the air intake heater. Follow the red wire back to where it terminates at an electric solenoid. You'll need to remove this end of the red wire as well.
There is a blue wire attached to the same terminal post on the solenoid. Leave this blue wire attached. If you do not leave the blue wire attached, a diagnostic scanner cannot do a full contribution test on your vehicle. Do not ignore this.
After you remove the wires, unscrew the heater and remove it. The new plug fits easily in its place. Only snug the Air Intake Heater Plug as it seals with a rubber washer. DO NOT OVERTIGHTEN.
Keep any wires so that you can reverse the installation if you ever want to.
Old Oct 27, 2010 | 09:36 PM
N4TECguy's Avatar
N4TECguy
The AIH isn't always on and it's not economically viable to put in an intercooler bypass that works for 5 minutes every morning.
Old Oct 27, 2010 | 09:41 PM
tritonman2001
thanks guys, guess it doesn't apply tome as I have an e99 7.3
Old Oct 27, 2010 | 09:43 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Correct, in fact many times you pull them out and they look brand new because they almost never activate. Here are the conditions and info.
The purpose of this product is to remove the restrictive Air Intake Heater from the intake air flow. Removing the AIH coil will not affect cold start up in any conditions. The PCM only commands the AIH to activate to reduce white smoke during extended long idle periods at low ambient temperatures. Specific conditions must be present before the heater is activated per Ford:
  • Ambient temperature must be below 32°F
  • Engine oil temperature (EOT) must be below 131°F
  • Vehicle power must remain between 11.5 and 15.0 volts
  • Parking brake must be applied
  • The transmission must be in Park or Neutral
  • Glow plugs must be off
Old Oct 27, 2010 | 11:38 PM
Diesel 724's Avatar
Diesel 724
FLEABAY has bread another moron! LOOK!
7.3 powerstroke AIH delete kit: eBay Motors (item 270653213416 end time Oct-29-10 21:03:45 PDT)
Old Oct 28, 2010 | 01:02 AM
Riffraff Diesel
PREMIUM SPONSOR
Originally Posted by Diesel 724
That's awesome! It looks like they copied my description almost word for word, LOL. Must be so top secret they can't post a picture.
Old Oct 28, 2010 | 01:59 AM
ron's power stroke's Avatar
ron's power stroke
must be a lot of copy cats...every where you look that sells it it is writen that way...
http://www.dieselsite.com/index.asp?...PROD&ProdID=48
  • ambient temperature must be below 0 deg C (32 deg F)
  • engine oil temperature must be below 55 deg C (131 deg F)
  • vehicle power must be between 11.8 and 15 volts
  • parking brake must be applied on manual transmission vehicles
  • the transmission must be on park or neutral on automatic transmission vehicles
  • glow plugs must be off
Old Oct 28, 2010 | 07:15 AM
Ponyboychris
More money to be spent on a different mod now.
Old Oct 28, 2010 | 10:07 AM
Riffraff Diesel
PREMIUM SPONSOR
Your right maybe several have, good point Ron. Of course I was specifically speaking about the wording not the bullet points that come from the Ford service manual.
Old Oct 28, 2010 | 11:02 AM
Diesel 724's Avatar
Diesel 724
Im surprised they dont claim it will "Take your truck from mundane to insane!"
Old Oct 28, 2010 | 11:04 AM
bama29fan's Avatar
bama29fan
Clay,
Can you comment on performing contribution test with this mod? can it be done....is there anything special to do it?
woodlander
Dec 13, 2014 06:56 PM
Redfridge
88
Nov 3, 2013 04:02 PM
Michael.simmons232
13
Mar 19, 2013 08:35 PM
rayezra
Oct 25, 2009 06:24 AM
