Window crank spindle diameter?
Old Oct 27, 2010 | 07:35 PM
crashtke's Avatar
crashtke
Anyone know the diameter of the window crank spindle? 1/2"? 7/16"?
Old Oct 28, 2010 | 03:21 PM
crashtke's Avatar
crashtke
Ok maybe a different way of asking this question. Does anyone know what the measurement is referring to? Is it the actual diameter of the rod? If so, I can measure that with some calipers. I just was not sure if it was the machined part of the spindle or the rod itself.
Old Oct 28, 2010 | 04:19 PM
Mike G's Avatar
Mike G
Depends on what you are trying to accomplish. I would pull out the calipers, or I was going to use a tape measure when I got home for you...
Old Oct 28, 2010 | 04:35 PM
OldHarley's Avatar
OldHarley
.437, so that would be a 7/16" rod. Top of the splines are about the same.
Sorry MikeG, about beating you to this, but lately you seem to have been getting into so much trouble when you try to help!
Old Oct 28, 2010 | 05:18 PM
crashtke's Avatar
crashtke
I was looking at some aftermarket billet window cranks and trying to determine which size to order. They had 1/2" and 7/16" sizes. But I was not sure exactly what they were measuring. My spindle is kind of gnawed down from the previous crank and I plan to order new regulators. I did not know what the thread (or cog I guess) size was on one that was not eaten away.
Old Oct 29, 2010 | 09:41 AM
Mike G's Avatar
Mike G
Originally Posted by OldHarley
...Sorry MikeG, about beating you to this, but lately you seem to have been getting into so much trouble when you try to help!
I'm speachless, but that's because I can't stop laughing.... --Thanks Greg!
Old Oct 29, 2010 | 10:44 PM
kstones63's Avatar
kstones63
My best suggestion is to take the window crank out and put a set of Saturn power window motors in the regulator and have the power windows. This is super cheap cheap and very easy to do. It might be cheaper thatn buying new window crank handles.
Kevin
Old Oct 29, 2010 | 10:46 PM
crashtke's Avatar
crashtke
have any details on this?
Old Oct 29, 2010 | 11:01 PM
kstones63's Avatar
kstones63
Here are the pics of mine.
The window motors came out of Saturn 4 door, approx. 2001 era. They are the front window motors. The salvage yards sell them with the motor and regulator. If you can find ones that the regulator is damaged they will usually let them go really cheap because they are useless to them.
The teeth on the motor meshes up perfectly with the teeth on the 61-66 regulators. The regulaters need to be modified some. They need a tab welded on the top to mount the 3rd bolt on the motor and it need to be notched behind one of the mounting bolts for clearance of the motor. This will all make sense when you try to mount the motor.
The motors need to be tilted slightly to the front to allow clearance for the wing window divider.
Be extra careful when you take the original window crank out as the spring is tight and can get away from you and hurt you.
Very simple and cheap.
Kevin
mb1096
20
Dec 12, 2019 01:29 AM
GaMachinist
Jun 12, 2014 12:40 PM
Infinite Monkeys
May 20, 2013 08:03 PM
Wallingnuma
Feb 12, 2011 09:14 PM
Ronindog
Feb 18, 2007 04:16 PM
