Trying to track down some frame parts for my truck. Rear upper shock mounts, and a couple spring hangers. Some of the only things on these trucks that just seems horribly designed to me, up facing cups, and mine are rotted to just nothing from all the mud that collects in them. I welded plates on to the hangers, but don't trust them as more than a bandaid.
Where can I find solid replacements? All the trucks around here have the same rust, I'd have no problem getting some from AZ or something though, don't need new.
LMC trucks has the upper shock mounts. They run about 45 bucks per side. I couldn't put a link to it cuz the site is blocked from Turkey for some reason. They can be kinda rough to find in their search engine, look for rear shocks they should be on that page. Good luck
1979 F150 2WD Rear Spring REAR Hanger Bracket (D3TZ5775D) is different from a 1979 F150 4WD (D8TZ5775B replaced by EOTZ5775C).
D3TZ5775D is obsolete, but can be found NOS from Ford Dealers, obsolete parts vendors.
EOTZ5775C is available from Ford since it also fits misc. 1980/96 F100/350's & Bronco's.
MSRP: $71.34 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $54.79.
----------------------------------------------------------------------------------- D8TZ18169A .. Upper Rear Shock Mount / Available from Ford.
Steponit, sorry if I made you feel passed over, it was not my intention in any way, and as an explanation, I actually read your post before the others responded, started reading the sponsors list, and got distracted. I then came back later in the night, saw the 2 new responses, and posted above.
I feel bad saying that your help got overlooked, but honestly that's jsut what it was, simple mistake. Sorry, and thanks!
To everyone else though, Tim, I know LMC has them, but I hate buying from them, everything I've ever priced out there has been so expensive, so I usually don't even bother anymore. John, that would be cool. And Dummy, as ALWAYS thankyou for sharing you knowledge. I have a 4X4, so the parts Blaze put up should work (they look exactly like my truck's at least), but I'll keep the info in mind if I go the junkyard route.
