SS HPX
Old Oct 27, 2010 | 05:36 PM
RobertJohn's Avatar
RobertJohn
SS HPX
Isn't there more than one sponsor that makes the SS HPX line ? I saw Ratliff's but thought there was another one ?
Thanks
Old Oct 27, 2010 | 06:17 PM
ron's power stroke's Avatar
ron's power stroke
KCM S.S. HPX Line (99-03)
Old Oct 27, 2010 | 07:38 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
^^^^^^^^^2X with Ron.
Old Oct 28, 2010 | 11:21 AM
Duck Hunter81's Avatar
Duck Hunter81
Is the KCM easier to install than Clays? I have been holding off buying clay's because I was told it was tough to install. It is $13 more and a little different design.
Old Oct 28, 2010 | 11:31 AM
timmyboy76's Avatar
timmyboy76
I bought Clay's S.S. HPX, and literally, took me 10 minutes to install. No need to remove spider, hoses, electrical..etc, nuth'n...remove the 2-plugs, install fittings, then feed the hard line under spider, i fed line, from driver side.
Old Oct 28, 2010 | 12:33 PM
duck fan's Avatar
duck fan
Because racetruck
Sounds like you were told wrong...
Old Oct 28, 2010 | 12:48 PM
PwerStroke99's Avatar
PwerStroke99
I have the KCM i bought years ago from Sinister(formerly ITP) Diesel. Easy to install.
Old Oct 28, 2010 | 02:10 PM
Kwikkordead's Avatar
Kwikkordead
I've put them both on. Both work equally well.
I went with the Sinister Diesel model simply because I liked the idea of the tube going under the intake vs above it.
The trickiest part about both of them is the o-ring gasket on the flanges that go into the HPOP rail on the cylinder heads.
Have to be very careful that you don't accidentally tear the o-ring as it's compressing down into the head.
Old Oct 28, 2010 | 02:22 PM
timmyboy76's Avatar
timmyboy76
Not follow'n you, on that one, chief. RiffRaff HPx (s.s.) i got, went under the spider assy?
