HELP stuck at work.
Old Feb 25, 2003 | 05:17 PM
bluemustang's Avatar
bluemustang
HELP stuck at work.
Truck will not start it turns over for a second and will not stay running. I checked to see if I have fire and it's getting that and I can move the throttle and see gas squirting in the carb. Any help i sure don't won't to stay here all night.
Old Feb 25, 2003 | 05:21 PM
okiebronco's Avatar
okiebronco
HELP stuck at work.
try holding the ignition key in different directions while trying to start it. sometimes with a bad switch that will get you started. sometime jiggling the key works also
Old Feb 25, 2003 | 05:26 PM
bluemustang
HELP stuck at work.
I'm going down to try it right now, I hope I won't be back till tomorrow to let you know.
Old Feb 25, 2003 | 05:29 PM
Chuck P.'s Avatar
Chuck P.
HELP stuck at work.
Try a new voltage reg., the rectangular flatish thing mounted behind the starting selenoid towards the cab. One of mine went in the way you have descibed.
Old Feb 25, 2003 | 05:46 PM
bluemustang
HELP stuck at work.
That didn't do the trick, I even checked the fuses under the dash, It ran fine this morning.
Old Feb 25, 2003 | 05:50 PM
bluemustang
HELP stuck at work.
I got in contact with my dad and he is going to come by and take a look at it, He knows alot more about it than I do. I will run the Voltage regulator by him. Is there any thing I can test before he get here.
Old Feb 25, 2003 | 06:07 PM
Chuck P.'s Avatar
Chuck P.
HELP stuck at work.
Try pulling the plug again and watch it once it does it's "almost runs" thing. If it's dark outside (if not find a helper to turn the key)this will show if your losing the spark as soon as you release the key/starter to the "run" position. That's how if found out mine was the culprit. Usual checks under the cap to make sure nothin' is amiss. Pull the fuel line after the filter and check for flow (carefully please!). Sorry I don't have more for ya.
Old Feb 25, 2003 | 06:10 PM
bluemustang
HELP stuck at work.
I'm on my way.
Old Feb 26, 2003 | 07:24 AM
bluemustang
HELP stuck at work.
Well this is what I found out, my fuel filter had a leak and the carb was not getting enough gas. I hope I have it fixed now. It did good this morning.
