a/c mounting help.
Old Oct 26, 2010 | 09:47 PM
wadar1969's Avatar
wadar1969
a/c mounting help.
I have a 351w that came out of an 81 model LTD, it has the a/c compressor, smog pump and tensioner pulley on the right side of the engine operated by a sepetine belt and and the alt,p/s pump and w/p on the left operated by another belt. Does this sound like the same set up that the 81 truck 351w had. If so could someone help me out by posting a pic of how the a/c,smog and tensioner brackets are mounted. I purchased the donor engine and the brackets were off and now I am trying to mount it all back on to my new engine. Any help is greatly appreciated.
Old Oct 26, 2010 | 09:56 PM
ctubutis's Avatar
ctubutis
1981 trucks had 351M engines, the W didn't come in trucks until 82-83.
Old Oct 26, 2010 | 10:00 PM
wadar1969's Avatar
wadar1969
Thanks CTU, I guess I need to try and find a pic of a 81 model car. Was the 82 model 351w set up with the a/c on the right side ?
Old Oct 26, 2010 | 10:08 PM
86351wProject's Avatar
86351wProject
I have an 86 351w v belt. My AC pump is on the drivers side at the top of the motor. This is where i have seen all of them. Even in the newer serp motors.
Old Oct 26, 2010 | 10:28 PM
wadar1969's Avatar
wadar1969
thanks 86351 I guess the car engines are diffrent.
Old Oct 27, 2010 | 12:40 AM
first today's Avatar
first today
The serpentine on the trucks were the same as what you have. The ones I look at in the JY have two serpentine belts. Later in the 80's they went to a one piece serpentine.
I think they ran the two piece serpentine because the water pumps did not have reverse rotation.
Old Oct 27, 2010 | 12:49 AM
wadar1969's Avatar
wadar1969
yea first mine has the 2 belts with the regular rotation w/p. did the trucks have the a/c on the right and the alt on the left like the cars?
Old Oct 27, 2010 | 12:58 AM
first today
Looking at the engine, the alt is on the left and the a/c is on the right.
I went to the 1989 one piece serpentine for my future engine. I am going to go to the junkyard today for some exercise. I will see if I can get you some pictures.
Old Oct 27, 2010 | 02:10 AM
wadar1969's Avatar
wadar1969
thanks first. the one i need has the a/c on the left and the alt on the right if you are standing in front of the engine looking at it. The alt is just above the p/s pump. I know the engine came from a 1981 crown vic. Thanks
landozer18
Apr 28, 2015 12:25 AM
1996F150XL
May 27, 2014 06:16 PM
luconn3
Feb 5, 2012 02:15 PM
TheKirbyMan
31
Aug 13, 2009 09:15 AM
Mixolydian
Bronco II
Nov 13, 2004 10:54 PM
