Sponsored by: Real Truck
e250 vs 350-difference
Old Feb 25, 2003 | 04:11 PM
Ghostgunn's Avatar
Ghostgunn
I was on a rv chat thread and it stated that the basic differences between an f250 and f350 where the blocks in the rear is this true and could someone elaborate. Also which is the best dually rear end to use? thanks Ghostgunn
Old Feb 25, 2003 | 04:19 PM
DCSpecial's Avatar
DCSpecial
F-250 has a 2" rear block and a 8800 GVWR
F-350 has 4" rear block and a 9900 GVWR
The DRW F-350 has a higher GVWR
Both SRW trucks have the same springs though.
On the dually rear, are you talking about which gears
The 4.10s are better for towing.
Hope this helps.
Welcome to the site
Old Feb 25, 2003 | 10:09 PM
REKEPPEL's Avatar
REKEPPEL
The F350 also has a slightly larger frame modulas, not much but I think it's 4.6 to 5.0, I traded in my f250 for an f350 dually and doubled the pin weight for my fifth wheel. 2400# VS 4800# if you have a 7.3L diesel . I believe the 4.10 is standard rear end for the dually.
Old Feb 26, 2003 | 04:41 PM
Ghostgunn's Avatar
Ghostgunn
What about the fornt ends what are the differnece? ANY? ANd how hard is it to upgrade an older f250 to dually 350 and which reaer end to use? Thanks
Old Feb 26, 2003 | 04:43 PM
Ghostgunn's Avatar
Ghostgunn
I am sorry about spelling/typing bummed up hand yesterday -- should have proof read. again sorry..
Old Feb 26, 2003 | 04:46 PM
Yeti's Avatar
Yeti
If your talking 99 SD's and up , there are no differences in the front end , same axle.
What year are we talking about?
Old Feb 26, 2003 | 04:48 PM
DCSpecial's Avatar
DCSpecial
SRW SDs from 99-01 had the Dana 50 front.
SRW SDs from '02 on had the Dana 60 front
SRW SDs all years had the Sterling 10.5" Rear.
DRW SDs all years had the Dana 60 front and Dana 80 rear.
Front springs depended on the suspension package, u-code, v-code, or x-code springs
There are dually conversion kits, but I don't know much about them.
Hope this helps.
Edit: Looks as though YETI is a faster typer.
Ghostgunn
Feb 14, 2012 01:38 PM
Ghostgunn
Oct 27, 2004 07:33 PM
Ghostgunn
Mar 5, 2003 03:34 PM
