1978 - 1996 Big Bronco
83 WITH NO FIRE
Old Oct 26, 2010 | 10:38 AM
firemanjones172's Avatar
firemanjones172
83 WITH NO FIRE
ok my bronco is getting no fire out of the coil it has power to it nd i have changed it 3 times and the ignition modural and i have put ne wires and plugs and still mot getting any thing what else could it be i have done every thng i know. it is a 83 with a 5.0 in it
Old Oct 26, 2010 | 05:06 PM
cOpE!'s Avatar
cOpE!
You say you have changed the ignition modual? If not, try smacking with a hammer...Seriously, I went 4 months before switching to an HEI setup, getting by with an ocasional tap to the modual, she would fire right back up. I would start with the easy stuff, (i.e. smacking modual with hammer) then look at all the wiring. Check those fat round plugs that connect all the wiring to your modual, they corode and melt inside and cause problems. Take them all apart and inspect-clean-or replace.
