32 inch tires
Old Oct 26, 2010 | 09:29 AM
octaneforce's Avatar
octaneforce
32 inch tires
i got a set of very new 32 by 11.5 inch bf goodrich all terrian tires mounted on factory aluminum rims for my 92 f150 2wd. how bad should i expect these to rub? the truck sits pretty level since i have spring helpers in the front.
Old Oct 26, 2010 | 04:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Since 32s have been know to rub on a 4wd i would say they will rub harder on your 2wd
Old Oct 26, 2010 | 05:44 PM
mikebrawn1's Avatar
mikebrawn1
Well I hope you aren't talking about the little spacers in between the coils but anyway I have the cc844 coil springs in the front so my truck sits level and the only time my 32x11.5s rub is when I hit full lock turning.
Old Oct 27, 2010 | 06:21 AM
TexasGuy001's Avatar
TexasGuy001
If you have leveling springs or F250 springs in the front it should work ok. If you have those twist in things get them out of there immediately.
Even with 31s the tires will still rub the radius arms at full lock.
Old Oct 27, 2010 | 09:20 AM
octaneforce
i put on the tires yesterday and they didnt rub anything except for the bumper. i took the front bumper off and im going to make some spacers for it. otherwise, they worked out really well.
Old Oct 27, 2010 | 09:24 AM
octaneforce
Uploaded with ImageShack.us
here is a pic i took after i put the set on. i used my phone and it was starting to get cloudy out, so the pic kind of sucks. my front bumper is also off. i got this set for 190 bucks which is very cheap. well atleast for around here. the rims still need a good cleaning.
http://yfrog.com/eatruckkkj
Old Oct 27, 2010 | 09:39 AM
Diesel_Brad
Those are not factory alum rims. They are at least 8" wide
Old Oct 27, 2010 | 10:24 AM
Conanski's Avatar
Conanski
X2.. but I'd say they're 10" considering how little tire bulge there is. Either way it seems you stumbled upon the perfect wheel for those tires on your truck, any chance you could pop one off again and measure the backspacing? That's the distance from the inside lip of the rim to the hub mounting surface.
Old Oct 27, 2010 | 10:29 AM
ExtrmZ's Avatar
ExtrmZ
yeah i would say those are 10" wide, and with that kind of backspacing, they might not rub on the suspension parts. but it could still hit either the fender or the bumper in the front.
Old Oct 27, 2010 | 11:14 AM
octaneforce
what do you mean the hub mounting surface? sorry to sound naive, but ive just never heard of backspacing.
Old Oct 27, 2010 | 11:17 AM
BuckHammer's Avatar
BuckHammer
I'm in the market for wheels and am curious about yours.
Old Oct 28, 2010 | 03:09 AM
TexasGuy001
That worked out pretty good. I'd say that they are 15x10 too, at least 15x8. The definitely do not have the factory offset and stick out more.
Old Oct 28, 2010 | 09:14 AM
Conanski's Avatar
Conanski
This measurement is what we're talking about..
Old Oct 28, 2010 | 09:25 AM
Hitokori's Avatar
Hitokori
4" of backspacing is what you need any less ur gunna look like a mexican any more and ur gunna be rubbing parts of ur suspension u didnt know u had
Old Oct 28, 2010 | 01:36 PM
octaneforce
what have you guys done to make the bumper mount farther up, away from the tires? i was gonna stack up some washers but i think i am going to run out of threads on the bolts that stick out of the bumper.
Dogmann
Oct 11, 2013 05:26 PM
chevenstein
Apr 17, 2011 11:47 AM
59flatbedford
31
Nov 8, 2009 02:59 PM
brandonhoekstra1
Oct 3, 2004 09:50 AM
rebocardo
Oct 7, 2002 02:13 AM
