View Poll Results: NEED FUEL PUMP HELP
vBcode
0%
Voters: 0. You may not vote on this poll
Fuel Pump Problems
Old Feb 25, 2003 | 12:40 PM
BOAZTOBALCAIN's Avatar
BOAZTOBALCAIN
Fuel Pump Problems
CAN SOMEONE HELP. I HAVE A '91 FORD F-250 , 6CYL. MY TRUCK STARTED HESISITATING TO START, BUT CONSTANTLY TURNING OVER. AFTER A WHILE IT WOULDN'T START AT ALL, BUT CONTINUED TO TURN OVER. I LOCATED THE FUEL FILTER UNDER THE BED OF THE TRUCK. AFTER REMOVING LINE TO FILTER,I ENGAGED SWITCH WHILE USING REAR TANK AND GOT A STREAM OF FUEL, AFTER SWITCHING TANKS I REPEATED THE PROCESS AND GOT A JET STREAM. AFTER REHOOKING THE FUEL LINE I TRIED TO START TRUCK USING FRONT TANK. WHAT I GOT WAS AN IMMEDIATE START AND THAN IT DIED. TRIED AGAIN AND ENGINE CONTINUED TO TURN OVER CONSISTANTLY, BUT IT WOULD NOT STOP. AND UNTIL I UNHOOKED THE BATTERY IT WOULDN'T STOP. WHAT I NEED IS WHAT CAN YOU GUYS TELL ME. NEED HELP WITH LOCATING FUEL PUMP. AND CUT OF SWITCH
Old Feb 25, 2003 | 04:42 PM
steve83's Avatar
steve83
Fuel Pump Problems
Try retyping that WITHOUT THE ALLCAPS. You might get a few responses. I didn't even try to read it.
