Airbag indicator (2 + 9)
Old Feb 25, 2003 | 12:06 PM
mighty_mouse's Avatar
mighty_mouse
Lightbulb Airbag indicator (2 + 9)
Hey guys my 2001 Expy airbag light is flashing 2 then 9 and repeat the sequence 3 or 4 times then stay solid......
Any ideas what this code is and how to fix it?
Thanks.
Old Feb 25, 2003 | 11:31 PM
Racerguy's Avatar
Racerguy
Here is what the manual says about a code 29......
The restraint control module (RCM) monitors the electrical condition at C2005 pins 10, 13 and 14 to determine if it is installed on the correct vehicle. Each vehicle configuration (Expedition with and without side air bags and Navigator with side air bags) will have a unique vehicle ID. See the tables below. If the RCM detects other than the expected programmed condition on any of these pins, it will store diagnostic trouble code (DTC) C1414 in memory and flash a lamp fault code (LFC) 29 (or higher priority code if one exists) on the air bag indicator.
Have you recently had any work done on the air bag system?
There is a whole series of pinpoint tests for this code. Essentially if the wiring is ok you end up replacing the Restraint Control Module.
Old Feb 26, 2003 | 10:17 AM
mighty_mouse
Hey Racer,
Thanks for you response, and yes I recently changed the AB system because a bump I had that deployed the airbags and the seat belt pretensioners..... but every thing is new, from the dealer, in fact I had to give them the VIN to get the parts....
but you are right, I know that are modules that monitor side
AB and modules that does not.... in my case I don't have side
bags....
Exists the possibility the dealer gave me the wrong module..?
I just installed directly from the box and did not check the part#...
Oh men..!!!!! is a pain get to the module just to check it...
Is there something else in your manual..?
Thanks
Old Feb 26, 2003 | 07:33 PM
Racerguy's Avatar
Racerguy
If you have the old RCM around still I would compare the part numbers on it to the new one. I'm not sure about yours but some RCMs have to be configured with a scan tool when they are installed. I can do some more digging for info if you need.
Old Feb 27, 2003 | 09:37 AM
mighty_mouse
Yes, I have the old module in fact, I connected it and I got the
LFC 19.......
But in order to compare the the part # on the new one I have to remove the central console because the module is behind it by the accelerator (task for the weekend).... If it results to be the same part#, maybe I have to take it to the dealer (as you said) to be programmed...... (aaggghh!! they will want to charge as if it was a world task just for plug the scanner and push 2 or 3 buttons)...
Thanks
fnx4wheeler
Electrical Systems/Wiring
Dec 27, 2012 07:50 AM
Shark Bait
Feb 25, 2010 07:29 PM
chaser1602
1997 - 2003 F150
Aug 31, 2005 12:37 PM
