04 Exp 4 low
Old Oct 24, 2010 | 02:00 PM
magnakidv4's Avatar
magnakidv4
04 Exp 4 low
Hello. I've been lurking here for a while but now I need some help. My wifes 04 Expedition somehow put itself in 4 low without the switch being turned or the transmission in neutral. How could this happen? I was able to get it back into 2 wheel drive by putting it in neutral and cycling the switch. Could this be a gem module problem?
Old Oct 24, 2010 | 09:47 PM
alloro's Avatar
alloro
No not a GEM issue, in fact I could be off a year but I don't think the GEM was still used in 04. There is a separate 4x4 module inside the dash behind the instrument cluster. The cluster has to come out to access it.
The other possibility is the shift motor is acting up down on the transfer case.
sensibull
30
May 8, 2012 02:02 PM
02whtmax
Nov 13, 2011 06:21 PM
kdavis4x4
Dec 21, 2010 05:05 PM
delmar2
2004 - 2008 F150
Dec 24, 2008 03:55 PM
wforacing
Feb 27, 2007 05:18 PM
