Sponsored by: Real Truck
snow plowing
Old Nov 25, 2010 | 07:14 AM
spdblos944's Avatar
spdblos944
Trailering
I have a 2006 F250 SC 5.4, 3.73 gears. Been doing commercial lots with it fours years now. It pushes the snow fine, you will not be disappointed.
Old Nov 25, 2010 | 07:16 AM
Bobcat7's Avatar
Bobcat7
I plow lots and drives in MI's UP w a 99 f-250 reg cab 5.4 w 4.30's from a v-10 rig. I use HALF the fuel dollars as I do when I have to jump in my 97 f-350 7.3 w 3.55's. The rear ratio is prob what kills the fuel mileage but... the turbo on your diesel never really gets to spool up and give you any boost / power / efficiency.
And if I gotta stomp on the 5.4 just before I am gettin' bogged down in the thick stuff - she jumps! Not to mention the front axle weight savings.
I believe the ford owners manual recommends against a plow on the 7.3 ( 1997 anyway) but they limit a trailer to 9200 lbs too so what do they know. A F-350 w a 7.3 and the mgtwr is only 9200#?!?! Come on.
Old Nov 25, 2010 | 07:33 AM
rjfetz1's Avatar
rjfetz1
I too plow with my 5.4 with a Boss 9'2" VEE. Pushes snow right out of the way!
Old Nov 25, 2010 | 07:44 AM
sammy77's Avatar
sammy77
Originally Posted by BerettaMan
I have an '02 F250, 5.4, 3.73 gears, 8 1/2 foot Fischer Minute Mount. I have never had a problem plowing. Have even done 95 mph with the plow mounted.
Umm......why?
Old Nov 25, 2010 | 08:29 PM
BerettaMan's Avatar
BerettaMan
Ummm....why what?
Old Nov 25, 2010 | 09:47 PM
LaxPlaya21's Avatar
LaxPlaya21
I've plowed with a 06' F250 5.4 with 3.73 and it did a fine job plowing. The only time I noticed that the truck was underpowered was when I would be commuting between jobs. Between my 800lbs plow and 600lbs of sand bags in the bed... it def took a little time to get it up and going compared to my 6.0 and my 6.4. In terms of reliability... the 5.4 3valve will not let you down.
Old Nov 25, 2010 | 09:49 PM
LaxPlaya21's Avatar
LaxPlaya21
I think he wants to know why you would ever drive 95mph with a 800lbs piece of steel mounted to your truck. I think he wants to know why you would be so reckless.
Old Nov 26, 2010 | 07:22 PM
BerettaMan's Avatar
BerettaMan
Post
Nothing reckless. Dry desolate straight dry road, sunny clear day. Just wanted to see what my new Ford truck had in her.
landscapeguy
6.2L V8
71
Jul 11, 2017 12:42 AM
Banshee25
Jan 24, 2017 05:09 PM
Walleye Hunter
Dec 7, 2016 01:20 PM
Agri-Cover, Inc.
Vendor Specials, Discounts, Product Announcements & Group Buys
Oct 16, 2015 11:21 AM
taylorjs
Nov 20, 2006 07:52 PM
