Timing issue
Old Oct 24, 2010 | 03:11 AM
dwegner's Avatar
dwegner
Timing issue
Hi, i have a 96 f-250 5.8 EFI with no timing tab, all there is, a crank positioning censor which is mounted where the tab should be and also a three (3) pointed sprocket behind the harmonic bal. that i assume is what the censor picks up on. Is there supposed to be a timing tab? If so where can i locate one. Thanx in advance.
Old Oct 24, 2010 | 09:20 AM
skyfox10's Avatar
skyfox10
define timing tab. Are you refering to the spout plug?
my 96 f150 5.8 has the CPS as well, but everything else times just like the older trucks. Although every time I pull the spout and set timing, it throws a code. So every time I set timing I have to clear it.
Old Oct 25, 2010 | 04:23 AM
dwegner's Avatar
dwegner
no what i'm talking about is the timing pointer that mounts on the timing chain cover. mine was missing when i bought the truck and i can't locate one anywhere. so there fore am unable to set timing.
Old Oct 25, 2010 | 08:40 AM
skyfox10's Avatar
skyfox10
ah gotcha. I know thes can be replaced. I saw a guy of FSB buy a replacement because his was screwed up, I don't remember where he got it though.
