Sponsored by: Real Truck
Tune up time
Old Oct 23, 2010 | 09:57 PM
bohiaa's Avatar
bohiaa
Tune up time
Howdy Boys:
ole Boe here From Texas, wanted aome advice on Changing the plugs and C.O.P.S on my 2000 F250 V10. She started to have a rough idle and using a ton of fuel. she hit 120,000 and as far as I kno she hasn't had a tune up sence she was NEW. I think the MAP sensor and IAC need cleaning too, that may be the idle issue.
any help, or Suguestions ?
also, are there any special tools needed?
Thanks
Old Oct 23, 2010 | 10:17 PM
jc8825's Avatar
jc8825
You will need a special tool if a plug breaks off. Might be best to let the Ford dealer do it...
Old Oct 23, 2010 | 10:24 PM
Fordfanatic4life's Avatar
Fordfanatic4life
thats only the 05+ 3V mod motors that tended to snap the first generation plugs in 1/2...
most important part is to clean the holes before removing the plugs, and be sure to use a accurate torque wrench.. setting the plugs in with the correct torque setting is vital.
p.s. my vote is to use Motorcraft parts only..these Ford mod motors dont like aftermarket parts.
