Engine lopes at cold start.
Old Oct 23, 2010 | 09:20 PM
1965joker's Avatar
1965joker
I have a 2001 F350 7.3L 4x4. The engine will lope if it has not been started for more than 2-3 hours, really bad when it's cold. After it's been started once and warms up a little it will not do it again. If you tap the accelerator pedal it quits. I replaced the throttle position sensor (accelerator pedal ) and the cam position sensor.
Old Oct 23, 2010 | 10:06 PM
schlepprock250's Avatar
schlepprock250
That is what we call the"romps",usually a change to synthetic oil will stop it from doing that.
Old Oct 24, 2010 | 12:40 AM
clintbonnie's Avatar
clintbonnie
Like Phil says... switching a synthetic oil like Shell Rotella 5w40 will fix the problem... this oil is thinner on cold starts up and help your hpop and injectors work properly... your engine will also run quieter .. better for the turbo also.. you can run it year round..
And a Big Welcome to the forum..
Old Oct 25, 2010 | 12:14 AM
1965joker's Avatar
1965joker
not the problem
I tried ti start it today it was 70 degrees. that's no my problem. When I said cold I meant have not been running in 2-3 hours and engine not warm, not outside temp, Thanks anyway for the feedback.
Old Oct 25, 2010 | 12:18 AM
big poppa's Avatar
big poppa
Bad glow plugs I suspect, this is the time of the year they show themselfs if their bad or not.
Brodude07
May 11, 2017 07:06 PM
kxriderforlife
Jan 17, 2017 06:06 AM
kxriderforlife
Jan 17, 2017 12:08 AM
82fordguy
17
Aug 14, 2016 09:27 PM
drjoe171
Oct 20, 2015 04:22 PM
