Trailer ball binding
Old Nov 6, 2010 | 01:21 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by fordman1090
How do you know if its to tight? Well, along time ago there used to be a commercial of a sedan pulling a medium sized trailer, and the equalizer was so tight that the rear tires of the sedan were of the ground haha. Obviously that's to tight. All you want to do is take the sag out of the rear end so that it sits level. You still want weight back there, and you dont wanna over load the front of the truck, or the already loaded axles on the trailer.
Creaking is normal when pulling a trailer, it can be a number of things. from the tow vehicle suspension to the hitch to the trailer it self.
Well said!
Steve
Old Feb 11, 2011 | 08:26 PM
Junebug_'s Avatar
Junebug_
Originally Posted by spinella
right i meant to not grease the bars where they touch the cams. at the hitch is good.
Not true on the Equal-i-zer hitch. The manual specifically states to use lubricant on the spring bars where they contact the L braces. I spray a little white lithium on mine every few trips and we have no noise at all.
Old Feb 11, 2011 | 09:49 PM
spinella's Avatar
spinella
heres a link. find your set up and they have set up tutorial. i thought you had a reese dual cam. i re-read your post. hope the link helps.
Weight Distribution - Reese
i was talkng about a reese dual cam. my manual says no greese on the cams.
Old Feb 11, 2011 | 11:10 PM
TexasRebel's Avatar
TexasRebel
that's not entirely true either... unless it has changed since 2007...
Equal-i-zer states to use minimal lubricant such as liquid graphite to quiet the noise if desired... They actually recommend not lubricating the bars, as use of heavy oil or actual grease will negate the anti-sway capabilities of the hitch.
RumpityRump
All Things Towing
Jun 5, 2015 10:33 AM
smiley87
Apr 12, 2015 06:30 PM
Hamburgerfella
Jul 19, 2011 11:45 PM
mrad
May 18, 2009 09:00 PM
Seaplane19
All Things Towing
13
Jun 30, 2004 05:54 AM
