New Thread: Looking for help
Old Oct 23, 2010 | 12:53 PM
Allen_70's Avatar
Allen_70
I have an '88 F-250. It quits when it warms up and will not start again until it cools off. I have replaced the distributor assembly, wires and plugs. I have not changed the main coil and it is not the T-stat. Any advice would be appreciated. Thanks.
Old Oct 23, 2010 | 01:40 PM
jpcnorthwood's Avatar
jpcnorthwood
The first thing you need is a code reader. I think mine cost me about $30. Pull the codes and see what your truck has to tell you.
Old Oct 23, 2010 | 01:43 PM
ymeski56's Avatar
ymeski56
Der Postmeister
It is customary to replace the TFI module (ICM) at the same time as the PIP (stator) is replaced. See Link: http://www.fordfuelinjection.com/?p=25
Old Oct 23, 2010 | 01:56 PM
skyfox10's Avatar
skyfox10
X2, I think it sounds like a TFI module. Whatever you do, make sure that the replacement TFI (if you get one) is the same color as the one you took out. If you swap between black & gray, you will have issues.
