6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
First lab report. Thoughts?
Old Oct 22, 2010 | 06:21 PM
KC8QVO's Avatar
KC8QVO
Sorry for the blurry text. I don't have fancy photo programs and did a screen shot from the PDF with some tweaking in Microsoft Paint
How do some of your early reports compare? It doesn't sound like mine is too out of whack but I would be curious as to how the engine wears later.
Old Oct 22, 2010 | 06:43 PM
senix's Avatar
senix
Well the fuel in the oil would be my only concern at the moment. Have you done any towing with this motor? Or had and some long drives yet?
If I recall these are not so much city traffic miles are they?
Old Oct 22, 2010 | 07:02 PM
KC8QVO's Avatar
KC8QVO
I would say about 20% of the miles are city, if that. The rest is rural country roads with some highway. No towing at this point in time. It is driven about 50 miles every day, or more, when it is driven. A couple trips have been up to 2 hours/100+ miles one way.
Old Oct 22, 2010 | 07:14 PM
senix's Avatar
senix
Steve,
I am a firm believer that this motor needs a hard run to seat those rings. That will help with the fuel getting past the rings into the crankcase.
If you can arrange a heavy tow I'd recommend that....or at least go get a car hauler from u-haul or something and take a long steep grade..would be good if you can put it to the floor and hit that hill and work that motor.
Just my thoughts, other than that I agree with Blackstones thoughts.
Old Oct 22, 2010 | 09:37 PM
pyro2nite's Avatar
pyro2nite
I agree about the fuel in the oil. With a new dpf it should be around 1.5 to 2. Mine looked like your report except for the fuel at the same milage. The fuel went up as the dpf aged, 4.5. It was changeed out under warrenty at 55,000 miles and it went back down to 1.5.
