ijjectors voltage
Old Oct 22, 2010 | 02:10 PM
mrwrench's Avatar
mrwrench
ijjectors voltage
should I Have 48v on the injector harness KOEO ?
Old Oct 22, 2010 | 02:13 PM
npccpartsman's Avatar
npccpartsman
I'm not sure how long it will be 48v after key on. You are better off to check FICM voltage directly AT the FICM.
Old Oct 22, 2010 | 02:39 PM
mrwrench's Avatar
mrwrench
Ficm voltage is 48 volts
Old Oct 22, 2010 | 02:49 PM
npccpartsman
Did you check also check it while cranking the truck? if it falls below 45v then your FICM (or batteries) is faulty
Old Oct 22, 2010 | 06:34 PM
cheezit's Avatar
cheezit
check at cranking, koeo and at 2k.
be carefull when playing with the injector harness. 48v 15amp. it will leave a mark.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
