Stranded headed back from the smokies
Old Oct 24, 2010 | 05:35 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by gmhorse
190 Miles from here to where Scott is. Tow bill was nasty at that distance. Spartan Diesel arranged for my truck to be towed in, and are trying to get someone in on Sunday to look at it. I am not sure where the ICP is located. There are two sensors on top of the passenger side valve cover. It seems I remember that one of these was the ICP? Anyway I unplugged both of these and no change. I am assuming that I should have more than 230psi reading on my ICP. AE software showed 680psi called for, and only 230 psi actual. Anyway, I will keep you informed of the outcome and my experience with Spartan Diesel. Thanks to everyone for your help. Your expertise and help are most appreciated!
I knew the tow bill would be bad IF you had to go that route. I was just trying to get you some help. Glad the Spartan folks got you some help. Good Luck.
