Premium Diesel?
Old Feb 24, 2003 | 10:29 PM
mediumfry's Avatar
mediumfry
Premium Diesel?
Easy question for some of you Diesel-Heads:
Some fuel stations say they have Diesel, others post Premium Diesel. What's the difference, if any?
Thanks
Old Feb 24, 2003 | 10:34 PM
pcwirepro's Avatar
pcwirepro
Premium Diesel?
I Have wondered the same thing. My SCMT literature claims to adjust timing to take advantage of "premium" fuel. I have never seen it.
Old Feb 24, 2003 | 11:32 PM
basstardo's Avatar
basstardo
Premium Diesel?
Usually, at least from what I've seen around here, it's just a difference in the Cetane rating. Texaco stations around here carry "premium" diesel (45 Cetane) and the rest pretty much carry 40 Cetane. The cost of 45 is usually about 10-15 cents higher than 40. I usually use Stanadyne with the 40 Cetane and it seems about the same as 45. When it's really really cold out, it also seems like the higher cetane fuel will help the truck start better.
basstardo
Old Feb 25, 2003 | 05:45 PM
jschira's Avatar
jschira
Premium Diesel?
Premium diesel can have a higher cetane rating, but it does not have to.
Refiners can put in better additive packages, more additives, or a higher cetane number and have the right to call the diesel "premium".
Cetane can vary from barrel of oil to barrel of oil. That is why most refiners will only say the "minimum" cetane number, usually around 40, but the cetane can vary from lot to lot from the low 40's to the upper 40's.
Amoco sells a "premium" diesel that they claim has a minimum cetane rating of 50.
Here is a link to BP Amoco that explains more:
http://www.bpdirect.com/products/index.html
