Transmission Question
Old Oct 21, 2010 | 11:26 AM
semperstrokin's Avatar
semperstrokin
I have moved out to the berbs, 20 miles one way stop and go traffic. I have noticed driving in traffic it helps when I have it in Tow-haul mode unloaded. Will it hurt the transmission driving like that everyday? Should I change the fluid more often? Thanks for your help.
Old Oct 21, 2010 | 11:38 AM
Misky6.0's Avatar
Misky6.0
Welcome to FTE, I'm also pretty new.....
May need to give more info:
What Year:
What vehicle:
What specifically do you mean it helps?
I would suspect, a description of the problem would likely result
in someone being to offer a possible diagnosis of a problem.
Old Oct 21, 2010 | 11:55 AM
cartmanea's Avatar
cartmanea
Running in tow/haul mode won't hurt a thing other than possibly the fuel economy. Changing trans fluid more often wouldn't hurt. I do about half city, half highway and I drain and refill every 20k.
Old Oct 21, 2010 | 12:00 PM
semperstrokin
Sorry, though my sig was on there, Is a 2005 XLT F250 6.0l, No Mods. No problems with the tranny. It seems to help in stop and go traffic because it stays in gear longer and I don’t have to ride the breaks as much, just wanted to know if it would damage the transmission driving like that every day. I have went through Bismic’s transmission thread a lot of good info there but didn’t find the answer.
Old Oct 21, 2010 | 12:45 PM
moebdick's Avatar
moebdick
No it won't damage anything and may even be beneficial since as you noted you don't need to brake as much and the tranny doesn't have to shift as much.
