Originally posted by bronco 1996 16 year old yep i am telling someone what to do because everyone who owns a bronco should know what kind of engine it has.
OK First of all I have had this Bronco for about 8 days, and I am still trying to find out info on it. The engine is a rebuilt but I dont know if it is original the original engine or not. I have got all the info from this thread that I can use. I will take the vehicle to someone who knows what they are talking about, not some one who is barely driving for a year!
An easy way to tell a 302 from a 351 is to look at the thermostat housing bolts. If you can get at the bottom bolt with a socket and extension it is a 351. If you need a wrench because the bolt is behind the timing chain cover it is a 302.
Originally posted by Racerguy An easy way to tell a 302 from a 351 is to look at the thermostat housing bolts. If you can get at the bottom bolt with a socket and extension it is a 351. If you need a wrench because the bolt is behind the timing chain cover it is a 302.
Thank you... Now how to tell if its a 351windsor, cleveland or modified?
Should be a Windsor. Clevelands stopped being used in the 70's and modifieds in 1980. Where is catalyst sticker? Ford used to put stickers with info for all engines used and you had to know what you had to know which applied to you.
Originally posted by mweeps Should be a Windsor. Clevelands stopped being used in the 70's and modifieds in 1980. Where is catalyst sticker? Ford used to put stickers with info for all engines used and you had to know what you had to know which applied to you.
The sticker says 5.0L but the vin # reflects a 5.8l. thats why I was confused.
mweeps is right ,however if someone changed the engine the way to tell would be that on a 351W the thermostat housing bolts go in from the front, into the intake manifold. On a 351C or M they go in from the top, into the front of the block near the ditributor as well.
OK 16 year old. So you've been working on cars for 6 years and driving on a farm for 4 years. Many of the people here have been working on and driving cars since long before you were born.
This attitude is coming from someone who is worried that they bought the wrong vehicle because your friends say bad things about it? If you expect much help around here, I would suggest being a lot more considerate of others.
You can count valve cover bolts. Windsors have 6. Clevelands have 8. Also, the dipstick tube on a Cleveland is on the front of the engine (in front of the passenger side head/valve cover). On a Windsor, it's by the driver side exhaust manifold.
