dash-information center
Old Oct 20, 2010 | 07:57 PM
fanofrskins's Avatar
fanofrskins
my information center when dark the other day. i shut if off to reset it, and the whole dash when dark. i drove it to work, that afternoon started it and everything was fine. this morning it happened again. i took it to the dealer and got the "can't repeat, can't help" line. it is less than a week old, so i demanded that they keep it until they can fix it.
i post this to see if anyone else has had this problem and have a fix. that way i have some ammo when they try to feed me some crap.
Thanks in advance,
Dean
Old Oct 20, 2010 | 08:18 PM
juneau76's Avatar
juneau76
Just so we're clear, what were doing when it happened? Just idling, driving, etc? Were you touching the little button to make it scroll screens or reset? I haven't had the issue, but it may be good info for someone else to help you.
Old Oct 20, 2010 | 09:09 PM
beidle99's Avatar
beidle99
Try holding the info reset button as you start the truck, it should take all your lights and gauges through the test mode. It will also give you some neat info like a digital tach.
Old Oct 20, 2010 | 09:48 PM
Mudd460's Avatar
Mudd460
Could be an intermittant loss of ground issue. Something like that is hard to find when it is not solidly broken. I work on medical electronics and intermittand issues expecially grounds are the worst to find.
Old Oct 21, 2010 | 11:46 AM
mpipg's Avatar
mpipg
I am having the same issue. Kinda wonder if there is some kind of sensor the prevents the lights to stay off during day light operations? all my dash lights come on at start, but turn off soon after the engine starts. the dimmer adjustment does not work during this time however, if i turn it all the way to the right the dome lights comeon. I will check during night time operations to see if it changes. I will post if I discover something. Will also beidle99 suggested.
Old Oct 21, 2010 | 11:56 AM
mpipg's Avatar
mpipg
Ok.. think I may have figured it out. Cover the sensor bulb on your dash with a sweatshirt. I did this and after ten seconds the dash lights came on and dimmer worked. I then removed the sweatshirt and the dash light went off again. So I belive your dashlights work along with our headlight sensor? Hope this help. I would like to know if there is an option to have the dash lights on all the time, so if anyone know I would appreciate it.
Old Oct 21, 2010 | 03:54 PM
fanofrskins
it happens in the morning when it is dark. the dealer says that ford said it is a normal condition that the dash lights to work differently when the switch is in auto mode. I told them it can't be normal at night when i can't see anything at all. they are keeping it again to check some more stuff. i read some where that it could be the battery, so i told them to check that too.
thanks everyone for the info. i'll keep ya posted.
Old Oct 26, 2010 | 08:07 PM
tilelayher's Avatar
tilelayher
I hate the sensor, today was a rainy day and in my other truck I would have turned on my instrument lights but you can't in the new 150 unless you cover the sensor with something, they need a manual override.
Old Oct 27, 2010 | 03:33 AM
fanofrskins
I finally got it to dupicate. I was driving into work yesterday, and it was out. I hit a bump and it flickered at me. I tapped it a couple of times and it came back on. It is at the shop now.
mrjeff
Escape & Escape Hybrid
Apr 18, 2019 07:16 PM
LARIAT 85
51
Dec 15, 2016 10:14 AM
cookingguy
Oct 9, 2016 02:51 PM
raysxb
May 20, 2015 06:47 AM
RM2738
6.4L Power Stroke Diesel
Oct 27, 2012 08:22 PM
