hey ya'll . was putting the truck back together when i broke something. i was wrestling th intake manifold on when i broke the plastic connector that protrudes out of the valve cover. i think the injector connector? can i get that pigtail that mounts underneath the valve cover or do i have to buy a new injector? it has 4 small pins inside of it and the piece that plugs to it mounts over it and uses a small metal retainer clip. ' 07 f350 6.0 thanks guys
Seems there was another member here that did the same thing, and went through hell, all the dealers told him it was not servicable, and needed a new injector but in fact it was available. Contact partsguyed, im certain he can help you out.
EDIT: I just found the post I was thinking about. The guy ended up finding someone to sell him the connector/harness of a used injector and re-pinned it.
Jumper from 12B637 to fuel injectors. Engine Serial #'s 6030201 and after. NOTE: Prior 1/30/03, 9D930 not servicved separately, part of 12B637 engine harness. Clip for harness to fuel injector retention is part # W301222, Injector Harness, Navistar # 1843796C9*, FROM 1/30/03, 2003 ; 6.0 8 Cyl, Ford 350 Series
I need more info or a pic to proceed, but this is a prelim finding in catalog.
What he's looking for is the coil/harness part of the injector that also retains the spool valve in the injector. I have one I'll sell you dirty, but it involves removing the injector. PM me if you're interested
Again, I apologize for bringing this thread back to life, but I'm in dire need of a couple of the connectors shown in the previous thread. A part number or any info on obtaining some would be greatly appreciated.
