help.
Old Oct 20, 2010 | 01:15 AM
george d's Avatar
george d
help.
I've got a 292 ranchero. starts great. idles great. step on the gas and it just bogs and I have to pump the gas to get it to move at all.
Old Oct 20, 2010 | 03:39 AM
CHELLIE's Avatar
CHELLIE
Could be your carbs power valve, have your carb rebuilt, also check the advance springs inside the distributor, check your vacumme advance diaphram, with a piece of vacumme hose draw a vacumme and plug the hose off with your tongue, and see if the plate in the dist does not move back to the static position, if it does the diaphram is bad and needs to be replaced, make sure all the advance parts in the dist. move freely, check for vacuum leaks.
after that, you could have something binding in your transmission or diff. your E Brake may not be releasing, if the eng will start and rev up, it may not be the eng causing the problem.
Old Oct 20, 2010 | 11:44 PM
46yblock's Avatar
46yblock
Great advice Redneck gal! Might add bad accelerator pump diaphragm as a possible, but that would be taken care of with the carb rebuild.
82fordowner
Sep 2, 2013 07:37 PM
ck27
New Member Introductions
Nov 9, 2007 10:10 PM
81fordf-250
The Next Generation
15
Nov 24, 2006 08:04 PM
RedandWhiteBrit
Feb 21, 2006 05:36 PM
kevcas
3.0L V6
19
Oct 24, 2005 05:11 PM
