Heres a question...DEF DELETE.
Old Oct 19, 2010 | 05:20 PM
srkr's Avatar
srkr
If someone comes out with a DEF delete tuner,exhaust pipe,,,etc. AND your out of warranty from Ford, would you delete your DEF?
If so Why?
If not, then Why?
Shane
Old Oct 19, 2010 | 05:41 PM
rickatic's Avatar
rickatic
Too early to speculate about that decision. I have 13500 miles on mine so far with no DEF concerns. The performance and fuel economy is so good I feel no need for a tuner like I had for my 6.0. I see what the DPF deletes for the 6.4 cost. When applied to the 6.7, the resulting reduction in fuel costs and DEF usage would have to be dramatic to ever recover the cost. I do see the aftermarket coming with a DEF solution sooner than later. That might be interesting.
Regards
Old Oct 19, 2010 | 06:47 PM
69cj's Avatar
69cj
You might also consider that no matter where you live, the newer the truck the better the odds that you will get smog inspections. A lot of states are already doing it on the 6.0's. The newer the truck the more expensive to delete and then replace.
Old Oct 19, 2010 | 08:12 PM
rickatic's Avatar
rickatic
agreed....
Old Oct 19, 2010 | 09:57 PM
Painted Horse's Avatar
Painted Horse
Like Ricatic, I see no need to chip or tune this truck. Plenty of HP for the work I need it to do.
Utah smoged even my 6.0L, So I know they would fail me if the DEF and SCR were missing.
So as long as they don't become a problem, I'll leave them in place.
Old Oct 20, 2010 | 07:28 AM
ruschejj's Avatar
ruschejj
My attitude will likely be the same on this 6.7 as it was on the 6.4 I had. If/when I need to pay out of pocket to replace the DPF I will decide if I will get a tuner.
Reasoning there is that the cost of a new DPF is nearly the same cost of a good tuner/delete system. So, it's not really a question of wanting to tune the motor, it's just the issue of where my money goes. I'd rather buy a tuner than a DPF.
TxFordGuy1
6.7L Power Stroke Diesel
Jan 29, 2012 12:13 PM
Tacswa3
Feb 26, 2011 08:28 AM
gascan
Nov 29, 2010 06:35 PM
rob_nc
May 12, 2010 11:00 AM
Parts Guy Wyatt
15
Dec 23, 2009 11:36 PM
