Will older model pistons work???
Old Oct 18, 2010 | 09:39 PM
timbodee's Avatar
timbodee
I am rebuilding a 300 out of a 1984 and currently looking for pistons. There seems to be an abundance of older model pistons and I was wondering if these pistons would work in the 84. the flat heads are plentiful and much cheaper. Any advice would be much appreciated. Thanks Guys.
Old Oct 19, 2010 | 08:52 PM
F-250 restorer's Avatar
F-250 restorer
IIRC, the flats are less compression than the EFI pistons, which have the D recess. What you need to know is the compression ratio of the pistons in question. Just because it has a flat top, doesn't mean anything. The EFI's are the highest I could find, w/o going forged. They are 8.7:1. IIRC Keith Black makes one with a higher cr.
Or you can bore your block to .050 over, and use 360 pistons. Drop in swap.
Old Oct 19, 2010 | 10:21 PM
timbodee's Avatar
timbodee
I guess what you are saying is that most any year 300 pistons will work and if the efi will work and give a little extra compression then that sounds great if I understood you correctly when you said they are compatible.
Old Nov 16, 2010 | 08:06 PM
kxkid661's Avatar
kxkid661
Trailering
thats not what he is saying some of the older pistons have a very short compression distance,with a piston compression distance of 1767 to 1776 and you should be ok ,less than that and you will be low on compression,thats not good at all for the 300 =6 if your going to rebuild it go for zero deck for more compression,ZERO and the standard piston like a H519p with efi head will give you about 10 to 1 and you can still run pump gas
OrangeJuice
Apr 8, 2010 02:02 PM
saleen065
Jul 8, 2008 09:06 PM
boardwalk72
Aug 6, 2004 08:08 AM
Deadman2891
Jul 4, 2004 11:15 AM
57fordfreak
Jul 11, 2001 09:14 PM
