cold mornings= crap.
Old Oct 18, 2010 | 08:56 PM
blacksoot25's Avatar
blacksoot25
Hope you guys can come through again. When it is cold in the mornings (60 or below) when I start the truck which starts right up fine,sometimes with a small amount of black smoke puffs out. if I don't let it warm up for about 5 mins at least when I take off to take my son to school. Once I hit 30 ish or above it losses power and even starts to drop rpms even with more throttle no rise in rpms. If I let off and cruise to the stop light about 500 or so feet and wait till the light is green and take off like nothing wrong for the rest of the drive. Any direction would be great I am at a loss. Oil was just changed. Thank you guys
Last edited by blacksoot25; Oct 18, 2010 at 09:25 PM. Reason: forgot to mention the smoke
Old Oct 18, 2010 | 09:27 PM
blacksoot25
I also get a lil black puff on start up when cold don't know if it came out on my edit sorry trying this from my phone
Old Oct 19, 2010 | 12:34 AM
puller45's Avatar
puller45
EBP valve may be sticking closed, I know they are not supposed to, but I have seen it happen, with the symptoms you describe except that it didn't get better. We were in Idaho hunting and got lucky enough to find an honest dealer with a mechanic who knew 7.3's Post Falls I think.
Old Oct 19, 2010 | 12:39 AM
blacksoot25
I thought so too but it gets better or if I just let the truck warm up in the driveway never happens at all
Old Oct 19, 2010 | 12:52 AM
Visseroth's Avatar
Visseroth
huh, weird, do you hear any hissing from the EBPV?
Old Oct 19, 2010 | 12:59 AM
blacksoot25
I don't the only thing I can make out of the ordinary is a flutter or erratic exhaust when it happens but clears up at idle then the truck is fine??????
Old Oct 19, 2010 | 01:33 AM
Visseroth's Avatar
Visseroth
how's your oil? do you have a AE tool?
Old Oct 19, 2010 | 01:42 AM
carltonwebb's Avatar
carltonwebb
Did u change the oil yourself or have someone do it? Mine was doing that after an oil change too. It would start fine, leave the driveway fine and then lose power and cutoff about 500 feet beyond driveway. It was a pain to get re-cranked and would hardly run. Once it got warm, it did not do that. It also would not do it if I plugged it in.
This past weekend I changed the oiland filter on it again and it has not acted up since. Before I did that, you could count on it to cut-off or lose throttle when cool outside and the temp hand below normal range. I am still in a wait and see but i definitely see a difference in the way it runs so far.
Old Oct 19, 2010 | 10:05 AM
blacksoot25
It acts fine the oil level is good I changed it not even 25 miles ago. And no ae tool ?carelton did you change the type of oil or switch to synthetic?
Old Oct 19, 2010 | 10:23 AM
blacksoot25
Also it was doing this before the oil change I thought it could make this better but with no luck I guess it is just cold bloodied hahahaha
Old Oct 19, 2010 | 04:37 PM
dn29626's Avatar
dn29626
Are your glow plugs staying on long enough? They should continue to heat after the engine is running for 90 seconds or so.
Old Oct 19, 2010 | 04:43 PM
blacksoot25
They seem to be fine I don't know how long they are on for I don't try to take off for at least a couple of mins when it does it but if I'm in a hurry I only wait about a min at least and it will do it also I'm not hot rodding around either
